Duratec, st170 gearbox dimensions help
Old Mar 20, 2012 | 11:19 AM
Dannygti's Avatar
Dannygti
Default Duratec, st170 gearbox dimensions help
Hello there guys, my first post on this forum and I have a lot of questions
Right, I'm wanting to know what 6 speed fwd gearboxes mount up to the duratec engines? I would like to know if the st170 gearbox would?*
Also, anyone who has dimensions available for total width of engine and box would be great. I'm new to the ford scene but willing to learn.
It's an unusual project that I want to fit a duratec with 6 speed poss the 2.3l and turbocharged into my Peugeot 106. Space is an issue obviously but where there's a will there's a way
I'm talking about the all aluminium duratec btw
Cheers Dan
Old Mar 21, 2012 | 11:20 PM
Dannygti's Avatar
Dannygti
Bump
Old Mar 21, 2012 | 11:42 PM
Straight_4_N/a's Avatar
Straight_4_N/a
im pritty sure the mt285 wont fit a duratec engine.
if your pushed for room why not go for an ib5?
Old Mar 21, 2012 | 11:51 PM
Straight_4_N/a
mt285
weight 46kgs
lenght 332mm
width (not sure ill check when i get mine off)
Old Mar 21, 2012 | 11:55 PM
Dannygti's Avatar
Dannygti
I'm all for suggestions, I do want to use a 6 speed box though.
Like I say I'm still learning with the ford stuff.
Cheers for the help
Old Mar 22, 2012 | 12:08 AM
Straight_4_N/a
well the problem is with it even though the st170 was marked up as a duratec is not its a zetec-e engine with some mods, you could use the 6 speed out of the Mondeo mk3 2.0 SCi box that use's a real duratec engine so it would be a direct fit but im unsure if it will even go into a 106's engine bay.
Old Mar 22, 2012 | 12:32 AM
Dannygti's Avatar
Dannygti
Thanks for the info.
Do you know what model box is in the Mondeo sci? I need to be able to buy the nice bits like LSD and a gearkit.
If not then I will make an adaptor plate to fit the st170 6 speed.
The duratec isn't 'much' wider (from what I remember) than my pug unit as it doesn't use a can belt and the cam chain in much more compact.
I'm pretty good at shoehorning big engines into little cars, I used to work at Westfield sportcars.
Ther is a guy on one of the pug forums who's fitting a Zetec turbo to his 106 so if the duratec idea fails I'll go for something like that.
Old Mar 22, 2012 | 12:42 AM
Straight_4_N/a
Ford Mondeo Mk3 1.8/2.0 Petrol CSi Ghia/Ghia X
Old Mar 22, 2012 | 12:45 AM
Dannygti's Avatar
Dannygti
Sorry, I didn't explain correctly. What is the model of the gearbox? Getrag/ mtx75 etc etc.
Old Mar 22, 2012 | 07:09 PM
Straight_4_N/a
sorry i don't know what the gearbox name is in that, im a zetec-e and zetec-se man
Old Mar 22, 2012 | 07:15 PM
Fiesta_Jed's Avatar
Fiesta_Jed
The st170 box will not bolt straight onto a duratec.
The mk3 mondeo duratec uses a varient of the mtx75.
Old Mar 22, 2012 | 08:13 PM
Dannygti's Avatar
Dannygti
Is this variant you speak of a 6 speed? I suppose a gearkit would be difficult to get hold of?
Old Mar 23, 2012 | 10:15 AM
Fiesta_Jed's Avatar
Fiesta_Jed
No its a 5 speed.
Its the only strong gearbox that fits the duratec.
Use mk1 focus rs gears.
Old Mar 23, 2012 | 10:23 AM
Dannygti's Avatar
Dannygti
So there no proper 6 speed alternative?
How about the Mazda 3 mps gearbox?
If not then I'd contemplate making a bellhousing adaptor to fit the st170 gearbox
Old Mar 24, 2012 | 11:20 AM
Fiesta_Jed's Avatar
Fiesta_Jed
You could use a mps box but I dont know how strong they are or how big they are.
Does it have to have a six speed box ?
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
mjonathan24
Oct 29, 2015 10:39 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
Marv888
Sep 26, 2015 03:44 PM
