cossie 4x4 sump
Old Mar 8, 2012 | 12:33 PM
stevemc's Avatar
stevemc
Default cossie 4x4 sump
Away to be taking the sump off as its leaking,got the sealant and the two half moon seals,any tips for putting the half moon seals in,the back one with the tails on it looks a bit tricky,any help on doing this job would be much appreciated.
thanks steve.
Old Mar 8, 2012 | 12:47 PM
COLEYST200's Avatar
COLEYST200
Just so you no its a big job if your doing it in the car you will need to hold the motor up and drop all the stuff from under it and the drive shafts will all so have to come off front prop off and use a very good sealer as there are gasgets and as the the harf moon just use some of the sealer to hold them in place
And welcome to passionford
Old Mar 8, 2012 | 10:09 PM
stevemc's Avatar
stevemc
Cheers thanks for the info.
IainRS1700T
Sep 25, 2015 06:44 AM
little bram
Sep 21, 2015 02:50 PM
tib2220
Sep 14, 2015 12:33 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
