solid engine stabilizer bar
Old Mar 8, 2012 | 10:00 PM
dude.james's Avatar
dude.james
Default solid engine stabilizer bar
just looking into how to make my engine more sturdy and whats everyones opinions on a solid stablilzer bar?
ive found that i could make a nice one to join the back of the engine (gearbox to engine bolts) and connect it to the subframe probably weld it to it and have holes so it will just be a bracket. in thoery this will stop the engine going backwards when engine breaking as my inlet is reallyyyy close the back of the engine bay.
Old Mar 8, 2012 | 10:34 PM
cosworthmad's Avatar
cosworthmad
Hi if the stabiliser bar were to be solid i.e metal on metal you will get vibration in the car and possible metal fategue. You can get o.e rubber stabbliser bar from a v6 vectra wich will work with approriate brackets and no vibrations.
Steve
manuel boeckx
13
Oct 3, 2015 02:29 PM
3drRich
Sep 13, 2015 07:32 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
FordJonah
Aug 22, 2015 08:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
