Checking & setting Cosworth Gaps
Old Feb 20, 2012 | 08:25 PM
Mungus's Avatar
Mungus
Default Checking & setting Cosworth Gaps
Hey guys,
Im sure this will already have been answered before so would be greatful if you could direct me ... or advise!
Im doing some diagnostics on my Saph which until this weekend was running. Then all of a sudden, it wouldnt restart. It doesnt have a spark at the plug but has a single spark from the king lead to an earth when ignition is on, but nothing further when turning over.
Have a new group A coil en route to eliminate that but been advised to check the gaps on the phase and crank sensor (and position of).
Is there a how to guide for this please? Still learning!!
Huw
Old Feb 20, 2012 | 08:34 PM
studabear's Avatar
studabear
you need to align the sensor lug on the crank pulley so its under the sensor, then using feeler gauges adjust the sensor position till you get the correct gap. I dunno what the gap is.
Phase sensor i'm not too sure
Old Feb 20, 2012 | 09:45 PM
chrisa3's Avatar
chrisa3
i beleive its 0.3mm on both. fairly obvious on the crank sensor. the phase sensor, if you take the dizzy cap and rotor arm off, you will see the sensor has a flat head screw. loosen that off and then set the gap at 0.3mm. Pretty straight forward
Old Feb 20, 2012 | 09:50 PM
lee2cossies's Avatar
lee2cossies
Sounds like the distributer is not timed correctly? Or the phase sensor is shot or needs the gap set. All the settings are in the manual. Aernt u local too me? If you need a manual iv got one here I can photo copy for u and a mate has one for sale local.
Old Feb 20, 2012 | 09:51 PM
daz1968's Avatar
daz1968
I had a problem very similar to this on my 3 door, ended up being a wiring fault on the phase sensor, I fitted a new one gapped and timed it correctly, and problem went away, so check the wires on the phase sensor as it is unusual for gaps to change so suddenly,
Old Feb 21, 2012 | 03:36 PM
Mungus's Avatar
Mungus
Thanks to all, will try tonight and update you
Lee, where are you mate?
Im in Pontypool
Huw
Old Feb 21, 2012 | 03:49 PM
lee2cossies
I'm in Merthyr Tydfil.
Old Feb 21, 2012 | 05:44 PM
Mungus's Avatar
Mungus
Maaaaaaaaaate, no way.
Know it well, family live there WIll have to arrange a meet
Thanks for all help and advise, shes running !!
Checked all gaps, they were spot on. Looks like a new phase sensor, dizzy and rotor arm on it already.
Took the CPS connector plug off, refitted and she fired up straight away... wahoooo.
Learned a fair bit about it all mind.
Cheers again
Huw
Old Feb 21, 2012 | 07:32 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Cheers again
Huw
Told you it would be that or the phase
Old Feb 21, 2012 | 07:40 PM
Mungus's Avatar
Mungus
You did mate
I have a brand new group A coil on the way... just in case I need it one day lol
Old Feb 21, 2012 | 10:51 PM
lee2cossies
Great news mate glad it's sorted! Yeah sure we can arrange the meet, we have loads of cossies over in Merthyr!
j.hammond1
30
Oct 31, 2021 05:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
