2.0 blacktop head removal help!
Old Feb 5, 2012 | 07:35 PM
locum8's Avatar
locum8
Default 2.0 blacktop head removal help!
Hi , I'm trying to remove the head from my 2004 focus 2.0 but I have a problem. I'm struggling to remove the head bolts. I've tried to crack them with a breaker bar but they just won't budge. Also are the 2 torx bolts, in between the spark plugs, head bolts as there a different size from the rest. any info would be much appreciated. Thanks!
Old Feb 5, 2012 | 07:59 PM
andi-p's Avatar
andi-p
There is 10 head bolts and none in between the spark plugs. I think they are water way plugs. When trying to loosen them you should try and have the shortest extension onyour bar as possible. Hope this helps.
Old Feb 5, 2012 | 08:25 PM
locum8's Avatar
locum8
Thanks a lot andi-p that's a big relief as I've rounded they 2 bolts trying to take them out. I will try the head bolts again tomorrow.
Do you need to take the cams off as I've left them on?
Old Feb 5, 2012 | 08:28 PM
andi-p's Avatar
andi-p
If you take the cams out you can use a short torx bit and can get more umph behind the bar
Old Feb 5, 2012 | 08:36 PM
locum8's Avatar
locum8
Will try tomorrow thanks!
Old Feb 6, 2012 | 08:26 PM
Churtz's Avatar
Churtz
Hw did you get on? Its always easiest to remove the cams first. I think you can get to 8 out of the 10 bolts with the cams in.
Matt
Old Feb 7, 2012 | 05:51 PM
locum8's Avatar
locum8
Evening all, quick update.
I finally managed to remove the head tonight to then be greeted by 8 bent inlet valves, all because some idiot (me) didn't time the belt up correctly
Now I read some where that the zetec engine is supposed to be a non interferance engine. Is this true?
Old Feb 7, 2012 | 05:55 PM
andi-p's Avatar
andi-p
The zetec engine is an interference engine. What you have to watch is the timing as there is no keyways in the pulleys so the proper tools are required.
Old Feb 7, 2012 | 06:02 PM
locum8's Avatar
locum8
Just shows you that you should not believe everything you read on the Internet.
Thanks for the help guys!
Old Feb 7, 2012 | 07:42 PM
Churtz's Avatar
Churtz
I've done loadsa zetec cambelts with a 19mm spanner for the cam flats and a 3/8ths extension to measure tdc on cyl 1!!
dombanks
Sep 21, 2015 08:38 PM
RSmark84
Sep 13, 2015 01:29 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
