Puma Problem, help appreciated.
Ok tyres on the front and rear were bought at same time however the rear tyres need replacing already after just a few thousand miles where as fronts are fine. I get knocking when going over bumps so i assume its the rear beam brackets or top mounts? would this also be responsible for the tyre wear?
cheers
cheers
Is it the inside of the rear tyres that are wearing mate? I had a MK5 Zetec-S that had been accident damaged and the beam was bent slightly this caused my rear tyres to wear on the insides very quickly. If the wear is quite even I would check the bushes as if they are badly worn the rear beam can move side to side whilst the car is in motion and cause the tyres to wear. If you can get the car in the air try and shake the beam and see if there is a lot of movement ad the rear bushes are quite a common failure and are an easy DIY replacement. Polybushes for the rear beam are around Ł30 delivered from ebay and stiffen the beam.
Hope this is of some help to you mate.
Cossikev
Sep 13, 2015 02:00 PM
