Escort RS Turbo cold start problem
Old Jan 29, 2012 | 08:10 PM
Fowley's Avatar
Fowley
Default Escort RS Turbo cold start problem
Hi
It takes 4-5 minutes to start. When it warms up it is fine.
It will only start if you do not touch the accelerator. If you do touch the pedal, when it has started it just cuts out?
Is it cold starter valve?
Any tips please?
I am going to get it set up/tuned professionally. Any recommendations in South Lincolnshire or Peterborough area please?
Old Jan 30, 2012 | 12:26 AM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Best place would be Harvey Gibbs at SCS
http://www.specialistcarservices.com/
Is very good with Ford
Old Jan 30, 2012 | 06:39 PM
Fowley's Avatar
Fowley
ok thanks.
Someone mentioned performancetec at Peterborough. Any experience?
Old Jan 30, 2012 | 08:33 PM
Seriesonersturbowady's Avatar
Sounds like if it's mfi set up possibly cold start, More than likely it's the plenum not being electromagnetically activated by the thermo time switch, I bet if you take the air filter off and get some one to crank it,push the plenum down just a tiny bit and it will fire right up, the start up cycle works to the water temp of the engine, if told by the ecu it will push the plenum down its self to allow more fuel/air, if this is not working then it's the coolest temp sender at fault or the thermo time switch. Failing them its the ecu, but this is rare to happen, I had this fault on my series 1 for years until I took a degree on mfi management, now I now how to fix all the issues, be careful though as if it only runs well when warm tis is because it on,y uses the ecu for cold start and full load enrichment,if the sensors are at fault then you have a good chance of it running lean at full throttle/max boost, good luck, in simple talk check thermo time switch/wiring, and coolest temp sender /wiring, will put money on it
Old Jan 30, 2012 | 09:30 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
This may help/give you some idea's
https://passionford.com/forum/ford-e...-me-crazy.html
Old Feb 5, 2012 | 11:47 AM
Fowley's Avatar
Fowley
I checked and some of fuses missing.
When I put the fuse in for the heated seat it started but was missing [lumpy], when I took the fuse out it running sweetly.
Obviously something effecting the spark?
Did I read that seats, cold start valve on same fuse/circuit?
Thanks for help so far!
Craig
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
A.t.p
Aug 15, 2015 11:37 AM
Archiejay
Aug 12, 2015 12:07 PM
Sjieter
Aug 5, 2015 09:47 PM
adriansaleem
Aug 1, 2015 09:28 PM
