E.G.R. valve new MK7 transit
Old Jan 28, 2012 | 03:27 PM
gazza71's Avatar
gazza71
Default E.G.R. valve new MK7 transit
Does any one no how much a egr valve for a small wheel base 57reg 85/t280 transit should be .Been warned could be as much as £280 for part ? seams steep
Old Jan 28, 2012 | 04:00 PM
botters's Avatar
botters
competant bodger
sounds about right rareley need replacing tho a good clean and freeing off of the plunger inside normally suffices
Old Jan 28, 2012 | 07:54 PM
twister's Avatar
twister
Yes they are around that price. They normally break the gears inside the unit.
Old Jan 28, 2012 | 07:59 PM
gazza71's Avatar
gazza71
sure someone told me something needs reprograming as well ? after new part is fitted.
Old Jan 28, 2012 | 08:10 PM
gazza71's Avatar
gazza71
think ive read they go quite often though had one done under warranty at 18000 and now on 87000 so had a canny run
Old Jan 30, 2012 | 07:29 PM
steve4i's Avatar
steve4i
yeah there around 300mark from ford, sounds like a duck when ya nock the engine off lol
they dont need programmed once the new one is fitted, just be prepared for a few corroded bolts
Old Jan 30, 2012 | 07:34 PM
flannigan's Avatar
flannigan
speak to the main dealers mate as there was a recall on these and they usually replace them foc !!!
Old Jan 30, 2012 | 07:36 PM
ghigo's Avatar
ghigo
as said above there are little tabs on the cover peel them back a bit then lift off the cover take a good look for missing teeth on the gears if all is good then just free it off, doesn't need programming,
although i was told u could buy repair kits for them to replace the gears without shelling out 300 for a new one however this isnt verified ,
hope this helps
Old Jan 30, 2012 | 07:43 PM
gazza71's Avatar
gazza71
Thanks for reply's people but had a new one put on today £202 and a mate put it on so all well though there was a few different egr's dearest being £300. Thanks again every one
Old Jan 30, 2012 | 11:10 PM
james kiely's Avatar
james kiely
i have been told that fiat use the same egr valve and are supposed to be a good bit cheaper than ford dealer prices
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
