hello i have bought this set of brembo calipers for my 2wd sapp cosworth
they were sold to me as focus rs calipers but i am having second doubts
as standard focus calipers are grey
can anybody see if these are from the focus MK1 rs or help me to identify ???
thanks for the help
not FRS ones, look like fiat coupe 20v ones due to fitting position on the rear for brake hose.
i have some of the fiat and frs ones on my workbench and i'll get some measurements for you to find out what they are if they're like the fiat ones.
ish...
if the distance between mounting holes is 130mm, then i'd put money on them being fiat coupe 20v ones, they will fit, i'll know for absolute certain tomorrow though.
main difference is fiat ones are not quite as long and fitting to the rear is different, fine for cosworth brake hoses though as i found out today.
they don't look right to be honest, but depends what you are planning to use them for.
you can get any to fit if you try hard enough, just whether it's worth it or not.
