what oil id thinner when cold?
Old Feb 22, 2005 | 06:05 PM
Chipperx2's Avatar
Chipperx2
Default what oil id thinner when cold?
10-30W or 5-40W and which is better for a zetec engine?
Old Feb 22, 2005 | 10:32 PM
rosco's Avatar
rosco
the correct viscosity of oil for a zetec is 5w 30. the lower the number means the thinner the oil. the 5 is for when warm and the 30 is for when cold
Old Feb 23, 2005 | 09:40 AM
Chipperx2's Avatar
Chipperx2
Cheers mate
Old Feb 23, 2005 | 12:45 PM
oilman's Avatar
oilman
Only use 5w-30 in a Zetec engine.
5w is thinner than 10w when cold.
Simon
Old Feb 23, 2005 | 01:03 PM
Fiesta__Kev's Avatar
Fiesta__Kev
Yea 5w-30
All i use in mine
Old Feb 23, 2005 | 09:22 PM
mrviper's Avatar
mrviper
would you use the same stuff in a zetec turbo ?
Old Feb 24, 2005 | 08:33 AM
oilman's Avatar
oilman
I would, but use a better quality one, most 5w-30 oils are semi synthetics, but if you are running a turbo then consider a top quality full synthetic 5w-30 likes the Motul 300v or the Motul 8100.
Tech specs here http://www.opieoils.co.uk/lubricants.htm
Guy.
Old Feb 24, 2005 | 09:14 AM
Chipperx2's Avatar
Chipperx2
OK, I recently changed the oil, just after I bought the car, and I put in 10-30w as it said it was ok for zetec engines opn the container but ever since its been lumpy on start-up
will get it changed on saturday, cheers for the info
Old Feb 24, 2005 | 10:30 AM
oilman's Avatar
oilman
That makes sense, a 5w will give you better cold start then a 10w.
Guy.
Old Feb 24, 2005 | 11:09 AM
Chipperx2's Avatar
Chipperx2
chhers mate, cleared my head
Old Feb 24, 2005 | 09:27 PM
rosco's Avatar
rosco
fords 5w 30 oil which is called formula e is 95% synthetic. would be good enough for a turbo zetec.
Old Feb 24, 2005 | 09:37 PM
Chipperx2's Avatar
Chipperx2
I just used some shite aftermarker semi synth stuff from the motor factors
getting changed every 5k anyway so it don't really matter
Old Feb 28, 2005 | 05:26 PM
markevans's Avatar
markevans
Choosing Viscosity Grade
The most known engine oil viscosity classifications are as follows:
SAE (Society of Automotive Engineers) Classification:
The SAE classifications characterizes the viscosity at low and high temperature of the lubricant. The grade is given by two numbers separated by the letter W (meaning winter).
The first number, followed by W represents the low temperature viscosity, 5W, 10W, 15W... the lower this number, the more fluid at low temperature the oils, the easier the engine starts.
The second number gives the high temperature viscosity: 30, 40, 50. The higher this number, the more viscous the oil when hot.
Old Feb 28, 2005 | 05:40 PM
markevans's Avatar
markevans
Default This will answer all your questions (link)
http://www.tuninglinx.com/html/a_oil.html
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
