Sierra power steering problem (strange)
Old Jan 11, 2012 | 04:30 PM
cosrep's Avatar
cosrep
Default Sierra power steering problem (strange)
Basically when I start the engine and its idling, the steering will immediately turn fully left all by itsself and stay that way. I can turn the wheel fully right without too much trouble but as soon as I let go the wheel it will go fully left again by itself. I thought the fluid might be shot so I drained it out and replaced it with fresh fluid and bled as it says in the haynes manual but no change.
Anyone come across this before?
Old Jan 11, 2012 | 07:00 PM
cossie891's Avatar
cossie891
Is the pump ok and does it have enough fluid in it
Old Jan 12, 2012 | 02:01 PM
cosrep's Avatar
cosrep
As I said I drained out the old fluid and replaced with fresh fluid. Cant see how a faulty pump would make the steering rack move by itself
Old Jan 12, 2012 | 02:17 PM
rog's Avatar
rog
I would hazard a guess that the rack is buggered, but have you recently bought the car or swapped hoses or anything like that??? Maybe something just isnt connected right, a long shot though.
Old Jan 12, 2012 | 02:19 PM
rog's Avatar
rog
Actually just had another thought....it may be a blocked or damaged return line from the rack causing back pressure and making the rack turn by iteslf, i'd check the hoses and pipes
nick8saff
Aug 16, 2015 05:35 PM
Vincereese
Aug 15, 2015 06:24 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
