focus 1.6 instument cluster fault....
Old Jan 3, 2012 | 03:59 PM
Rollinz's Avatar
Rollinz
Default focus 1.6 instument cluster fault....
just bought a daily runner to replace my van, but the dash goes wappy.....
one min its fine. next min all dials die and allw arning lights illuminate, then it starts "bonging" then goes back normal,,,
done some googleing and turns out its quite a common fault...
whats the actual method of repair?
or.... i have a spare dash. (actually 2) 1 from my focus rs, and one from an ST, will these work if i just fit these? or are 1.6 dash's diferent wiring wise?
cheers in advance
Old Jan 3, 2012 | 04:04 PM
andi-p's Avatar
andi-p
i have heard from a friend that has had this fault the spraying the circuit borad inside the cluster with wd40 (or similiar penetrating oil, Other brands are available...LOL) this helps with any dry joints in the soldering oin the board. Hope this helps.
Old Jan 3, 2012 | 04:09 PM
Rollinz's Avatar
Rollinz
so if its a dry joint, it would be worth stripping and finding the offending joint and just re-solder it?
Old Jan 3, 2012 | 04:13 PM
andi-p's Avatar
andi-p
If you fancy doing that, crack on. There is loads of possible joints inside.
Old Jan 3, 2012 | 08:09 PM
martysmartie's Avatar
martysmartie
I would say the wiring will be different etc, for a start the RS does not have a temperature gauge!
If you are famalier with the excellent "Ford diagnostic" on these dashes you can check for DTC's that have been flagged.
I presume this is obviously a MK1?
Martin
Old Jan 3, 2012 | 08:45 PM
Rollinz's Avatar
Rollinz
Yes a mk1,
This is whats happening
http://www.youtube.com/watch?v=z7E1n...e_gdata_player
And no theres no dtc's
Old Jan 4, 2012 | 07:45 PM
luke19790_3's Avatar
luke19790_3
had this on my dads, i got one from ebay and replaced it was fine after that.
liamT74
Sep 23, 2015 10:24 PM
jonnyenglish
Sep 21, 2015 07:31 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
