Piston damage...... Pics, any suggestions
Old Dec 27, 2011 | 04:14 PM
mill5y's Avatar
mill5y
Default Piston damage...... Pics, any suggestions
Project escort, removed pistons and found some marks like valves had given them a kiss, 1 i could understand but all 4???
start with the head,
Bit dirty but no damage
Pistons after a clean-up with some neat petrol
All 4 marked in same place, no damage to head..... Has it had a snap and been revalved??????!!!!!!! Definatly not ment to be like that unleas they mchined them with a hammer and chisel because they are definatly knocked!!
Any ideas?? The valves are undamaged and the marks on pistons were all mucked up so guessing not recent, im pretty stumped as could be a number of wrong doings, head skim, gasket, wrong lift clearence, wrong pistons, wrong valves at some time.... Any ideas??
Old Dec 27, 2011 | 04:23 PM
Joshy's Avatar
Joshy
Dreamer
looks like timing has been out at some point maybe? and its been fixed on the cheap...
Old Dec 27, 2011 | 04:51 PM
steve4i's Avatar
steve4i
as above probs snapped a belt before and bent valves before due too crown down damage like that
gouch1's Avatar
gouch1
they have defo been in contact with the valves before and not changed
Old Dec 27, 2011 | 06:21 PM
mill5y's Avatar
mill5y
With it only being one side would that indicate one cam was out and thus only one set of marks
Old Dec 27, 2011 | 07:50 PM
Mark_'s Avatar
Mark_
more than likely the timing was slightly out causing the valves to come in contact with the piston,
Old Dec 29, 2011 | 05:06 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
my money is on a previously snapped belt. If its a n/a motor then i'd make sure the valves are sealing ok and then just clean the burrs off the pistons with some emery tape and oil
Old Dec 29, 2011 | 05:29 PM
Chaz888's Avatar
Chaz888
As said timing or belt snaped could be the head was swoped out with a replacement ?
Old Dec 29, 2011 | 06:23 PM
J1mbo's Avatar
J1mbo
B1mbo
Why if it's n/a any engine needs correctly seated valve not just a atmo one!
Old Dec 29, 2011 | 09:03 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
Jim, I think the n/a comment was more to do with the pistons rather than the valves. As you say, all engines need the valves to seat/ seal correctly.
Old Dec 29, 2011 | 09:07 PM
J1mbo's Avatar
J1mbo
B1mbo
Dosnt come across anything to do with pistons to me?
Old Dec 29, 2011 | 09:09 PM
flannigan's Avatar
flannigan
its over revving that causes this kind of damage mate if it were a timing belt failure the exhaust valves would have made contact too !!!
Old Dec 29, 2011 | 09:54 PM
mill5y's Avatar
mill5y
Heads going in shop tomorow for pressure testing clean up etc, may get a bit of head work done while its in...
Old Dec 29, 2011 | 10:01 PM
G420 DEL's Avatar
G420 DEL
my pistons were exactly same when i missed a gear! as said over rev!
Old Dec 30, 2011 | 04:43 PM
*Bri.4.b.Cos*
could have been worded better but Rob got what i mean't, Go find some tech thread to nit pick in
jessie_rs
62
Aug 6, 2019 09:27 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
chris m1
Sep 7, 2015 08:02 PM
routemaster
Sep 7, 2015 05:27 PM
