ERST minor problems
Old Feb 21, 2005 | 02:25 PM
Daz-rst's Avatar
Daz-rst
Default ERST minor problems
right new to the turbo scen and have no clue on any of this so bear with me please
every now and then the car tends to idle at around 500rpm and almost cuts out but never does. i know it shouldnt do this as it does when both cold and warm any ideas please.
also the heater does not work when put on position 1 all the rest are fine just number 1, ideas???
lastly what should i do next to the engine (mods wise) ive already got exhaust, filter, actuator, bleed valve, and im not sure if the heads been made stage one.
cheers
daz
Old Feb 21, 2005 | 04:43 PM
swrsturbo's Avatar
swrsturbo
Re the heater it'll probably be the contact on the back of the switch, get one from a breakers, they're all the same.
Next mod would probably be a chip so you can up the boost or a big 'cooler if you haven't got one already.
Old Feb 21, 2005 | 09:04 PM
Daz-rst's Avatar
Daz-rst
Default cheers
thanx mate never thought of a chip D`oh!!!!
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
