Ok cossie Qs again
Old Feb 21, 2005 | 06:33 PM
Alan s1's Avatar
Alan s1
Default Ok cossie Qs again
Ok had a look at the cossie to day as its still running rought and i have noticed that its still got the 3bar map sencer on it but its on yellows and the t3 turbo so it should be using the 2.5bar map sencer No
I have still to look to see if the car is chipped or not as i dont know
Basicly it idels fine and revs not to bad little spluttery BUT under load its missing and sputtering
The plugs are 3wks old And are as black as hell the car has only done 19 mile with the new plugs so the fueling most be well out
Also under load it smokkes alot on high revs 3,000 rpm +
Whot thing can i do to check next
Ps did a pressure test and all 4 cylds had 100 to 110 psi on them so the last person how did the test was talking sh!t as he said 1 and 2 was fu!ked
Old Feb 21, 2005 | 07:11 PM
Eagle's Avatar
Eagle
Super Moderator
if its a standard chip etc then yes im sure a 3 bar map sensor is incorrect ..
think i may have one you can have ...
sounds like overfuelling to me mate
what boost is it eunning???
Old Feb 21, 2005 | 07:13 PM
Alan s1's Avatar
Alan s1
Dont know whot boost its running as i int got a gauge
Old Feb 22, 2005 | 01:19 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
mine does the same, it's over fueling I give it some stick and I become James Bond with a smoke cloud behind me. LOL
I turned down the co in the ECU, but I think I might have to do another little twist.
Old Feb 22, 2005 | 06:28 AM
Alvyn's Avatar
Alvyn
100 psi is still low m8 but by the sound of it you got a mixture of components on it that shouldn't be there! get a 2bar on it and try an ecu that is running standard or stage1 chip to see if it will run and rev up properly and go from there
ps you may have to turn the fuel regulator down also!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
