lost keys
Old Dec 12, 2011 | 07:40 PM
dudesfezaddicition's Avatar
dudesfezaddicition
Default lost keys
hi all,
had a fun but icy day at cadwell on sat, i was loaded and ready to go but nephew's mk5 fiesta van 1.8 turbo diesel had flat battery at end of day , no credit on his phone, late for work, then broke and lost top fob of his keys! can we get away with changing keys locks and transponder jobbie or does ecu need changing? know it has immobilizer , had a feeling that fuel pump was connected to ecu? any ideas, other than scrapping!
Old Dec 16, 2011 | 07:34 PM
dudesfezaddicition
hi guys and girls, any one know? been suggested that fuel pump can be sorted with live feed but also told it needs to be reprogramed? can get keys,locks,transponder ring, imobilizer and ecu cheap and happy to swop but can't get the fuel pump that was with these, so will orginal one work? CHEERS
Old Dec 16, 2011 | 07:49 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
you could change the locks etc
or if its old style td then you could change the stop solinoid for an early one
i think maybe you will have tddi so its not that easy
maybe best bet is locks and ecu
Old Dec 20, 2011 | 08:18 AM
dudesfezaddicition
It's the tddi, 2001 i think
Old Jan 10, 2012 | 07:13 PM
dudesfezaddicition
HELP!!! have changed locks, transponder ring and ecu But replacement came with seperate pats box which his didn't have but have found a gemini imobilizer(maybe alarm) he didn't know it had, which looked to have been fitted profesionally but never had any fob for and car still worked so guess not active?
so basicly think his may have had pats build into ecu? the older safe guard type???any ideas how to bypass or connect pats box that his didn't have so no obvious place to plug in?
i know would proberly be easier to throw puma running gear in but he's only 17, any suggestions other than breaking? cheeRS
Old Jan 11, 2012 | 12:30 AM
bailey1981's Avatar
bailey1981
If its a late engine it will have a Bosch vp pump
these have there own ecu built on the top of pump & the pats is built in
only way round this is a new key programed to the vehicle.
If its the older style Lucas pump then you can just wire a 12v ignition feed to the stop solenoid
if you have the original ecu imobiliser chip reader etc
id re fit it & try a few key places as some may be able to.do it on reg plate
depends what sort of software they have
good luck
Old Jan 12, 2012 | 03:49 PM
dudesfezaddicition
thanks for advise fellow, it's the bosch pump, do you know would it be easier/cheaper to reprogram pump to new ecu or swop orginal bits back and get key programed? thanks again
Old Jan 13, 2012 | 08:18 AM
bailey1981's Avatar
bailey1981
Default ...
Id say get it all bck to original
but if you have a lock set & ignition barrel off the other car leave these fitted
& just get a new key cut to match from a blank & get someone to program it to the original ecu
It sounds complicated but its fairly straight forward
we had a few done at the garage i worked at
Maybe best thing ya could do is phone a mobile programer for there advice as some cut keys on site aswell as program them to ecu etc
Google for local key programers
& just ask there advice
Good luck either way
Old Oct 19, 2012 | 05:00 PM
dean2012's Avatar
dean2012
hi all,
if you go to this forum http://www.carkeyadvice.com/forum/fo...ey-Discussions you will surely read a lot of advices on how to solve that.
Old Oct 19, 2012 | 08:34 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
I'd have suggested just programming a new key...
MK5 Feesties use PATS 2 immobiliser. They're mega straightforward to code a new key to, and much less hassle than changing all the locks, ecu etc.
Get a decent auto locksmith to code all the original, or even the new parts with diagnostic software.
I use FoCom for pumps, injectors, PCM coding... and It does key programming too.
Old Oct 19, 2012 | 08:49 PM
RichieST's Avatar
RichieST
I'd hope he's sorted it after nearly a year lol
Old Oct 19, 2012 | 08:54 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
duh... just noticed the date on this post?!?!
I blame the other guy for bumping it up...
Old Oct 22, 2012 | 10:37 AM
dean2012's Avatar
dean2012
i didn't notice the date as well! well, i hope he got that solved too! and maybe my post can help somebody else anyway! cheers mates!
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
