Ford Ka / Focus ECU Problems
Old Dec 7, 2011 | 02:12 PM
Gazz_'s Avatar
Gazz_
Default Ford Ka / Focus ECU Problems
Long story short - I have fitted a Focus engine into a Ka but cannot get it to run. I assume there is a problem with the ECUs matching up and PATS preventing the car from starting.
I have the ECU printouts from both vehicles.
The PATS pins for the Ka are: #5, 38, 39, 32 and 41.
Would it run if I removed these pins completely or do they need to be plugged in somewhere?
Old Dec 8, 2011 | 05:53 PM
martysmartie's Avatar
martysmartie
You will need the key that was paired to the Focus ECU or rather the transponder within it, as at the moment I assume your using the original key?
Martin
Old Dec 8, 2011 | 08:39 PM
Gazz_'s Avatar
Gazz_
I have the key, transponder and ECU all from the same doner vehicle.
I have taped key is taped inside the transponder but it is still not going.
Any ideas?
Old Dec 8, 2011 | 08:55 PM
GVK.'s Avatar
GVK.
Focus immobilser runs through the instrument cluster, don't think it does on a KA.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
taylora1409
Aug 12, 2015 12:06 PM
