ALTERNATOR HELP ERST !!!!!!!!!
Old Feb 19, 2005 | 04:16 PM
rabmc's Avatar
rabmc
Default ALTERNATOR HELP ERST !!!!!!!!!
Right troops changed my alternator today , because my batt light was staying on when ignition was off so therefore killing my draining my batt in process , so cleaned my cables reconnected new alternator and went a drive for about 30 mins came back and damm lights still on checked blue wire connection on alternator and all semms ok , its not falling off or anything , so anyway where does this wire go to from alternator could there be a break in cable ? , fuse ?? any help appreciated guys its doing my head in now or anyway of testing it would be good or could there be a break in red wires ???
Old Feb 20, 2005 | 10:25 PM
velocity's Avatar
velocity
the blue wire goes to the back of the instrument cluster to your alternator light.but on the way it links into the relay for the heated windscreen as a blue and yellow wire.might be worth removing this relay to see of it helps i almost certin a mate had a similar problem and this was the gremlin
Old Feb 20, 2005 | 11:16 PM
Al Bags's Avatar
Al Bags
Yes .. the alternator output 12v wire (blue) is the one that feeds a signal to the
Heated Screen relay under RHS of dash. Check for water leaks over the relay, too
Old Feb 21, 2005 | 04:18 PM
rabmc's Avatar
rabmc
Old Feb 21, 2005 | 04:27 PM
rsboy82's Avatar
rsboy82
dude check for a loose connection on ya starter motor beczause i had the same propblem and it was the power wire from the alternator to the starter motor!!!!
Old Feb 21, 2005 | 04:33 PM
rabmc's Avatar
rabmc
Right troops seem to have cured it fingers crossed , right hope this makes sense from alternator (blue wire) to starter this cable was jointed onto another blue wire that goes away from starter into loom so could not see where it went this joint in blue wires was all corroded/rusted , took apart stripped and reconnected joint , put jump leads onto my car started it for about 15-30 mins shut off engine and no batt light so started and turned off engine 3 or 4 times and all seems okk , so hopefully thats what the prob was , what are these wires im talking about didnt seem to be doing anything just siitingthere near starter connections
Old Feb 21, 2005 | 06:46 PM
Al Bags's Avatar
Al Bags
Right mate ..
The Alternator warning light has an ignition fed supply (in the console) to one side of the light.
The other side of the light connects back to the Alternator warning light output .. It could have been botched by connecting somewhere else .. but the Alternator terminal is where it should be connected.
When the alternator produces a charge, this will then give you 12v on each side of the warning light, yes? Now a lot of folks dont understand this bit .... The bulb will go out, cos no current is flowing.
If the Alternator fails, the regulator inside usually earths (or partially earths) this side ... so you get a light on. So earthing this wire also puts the light on.
If a heated screen has been added, the trigger wire to the relay should originate from the warning light terminal - It's actually spliced inside the car on the way to the dash warning light.
You need to weigh up what you actually have in place; Is that blue wire connected to a thick cable or another (blue) thin one?
Old Feb 21, 2005 | 09:26 PM
rabmc's Avatar
rabmc
Blue thin 1 mate there actually the same sice , one has copper inside the other had silver inside i know this dos not matter much , but what was this joint doing at my starter if u know what i mean
Old Feb 21, 2005 | 10:06 PM
velocity's Avatar
velocity
that joint should not exist in the blue wire especially at the starter it should be one piece all the way to the splice off for the heated windscreen relay in the loom somewhere , i'd say you have the problem sorted,just keep the blue wire seperate from the starter and a good connection where you now have them joined
Old Feb 22, 2005 | 04:15 PM
rabmc's Avatar
rabmc
jonfoc
16
Sep 11, 2018 05:35 PM
Mc5506
Oct 5, 2015 09:57 PM
timsrs
22
Sep 24, 2015 08:14 PM
beller
Sep 21, 2015 04:13 AM
jay030787
Sep 18, 2015 04:38 PM
