24v conversion - show me your fans.
Old Nov 1, 2011 | 02:36 AM
mk22door's Avatar
mk22door
Fart of the Purniture
Default 24v conversion - show me your fans.
Doing a 24v conversion into a Saff, using the 24v granada radiator, got some twincam 8v Sierra fans and cowling but they won't fit!
No clearance between the back of the fan and the pully's on the BOA.
I thought everyone used them?
Ken lowe fan kit too expensivo, scared of cheap E-bay slimline fans, tried some from a v6 vectra too, but no joy...
Help please
Old Nov 1, 2011 | 05:46 AM
3drpete's Avatar
3drpete
Cosworth twin fans mate with a fan fitting kit off eBay, it fits through the fins on the rad,
Old Nov 1, 2011 | 07:52 AM
phatfordxr4i's Avatar
phatfordxr4i
put the fans on the front of the rad and make your own brackets
Old Nov 1, 2011 | 03:17 PM
mk22door's Avatar
mk22door
Sounds good mate, I'd like some photographic evidence before I buy anything, just got the money to do all this once only.
Old Nov 1, 2011 | 03:19 PM
mk22door's Avatar
mk22door
Come on people, photographs please
Old Nov 1, 2011 | 03:24 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
no photos but ive got a bob 24v rad in my xr4x4 v6 and ive got loads of clearance.
used threaded bar into chassis legs and bolted the top on rubber bobbins, similar set up to mk1 sierra.
i think bob fans are same as mondeo v6.
Old Nov 1, 2011 | 03:29 PM
mk22door's Avatar
mk22door
That's a great tip, I know someone who has just broke a Mondeo v6, cheers
Old Nov 1, 2011 | 04:40 PM
mick's Avatar
mick
not the best pics, a combination of twink rad and fans or 24v rad and twink fans all locted in the holes nearer the front for air con....
Old Nov 1, 2011 | 09:59 PM
mk22door's Avatar
mk22door
Excellent, that's great.
Seeing is believing as they say.
Old Nov 1, 2011 | 10:25 PM
mk22door's Avatar
mk22door
Note to myself..
Originally Posted by dojj
the fans are held in with 3 nuts/bolts and you simply undo the 2 securing bolts for the fan shroud, unplug the loom to the fans and pull it out
you can then mess about with it on the bench as the fans will more than likely have these threaded bits corroded
if the fan is siezed you can simply replace them and slot them back in again, almost the easiest thing to do on a sierra
apparently the diseasal fans used a slimmer shroud so you could always try and find them
alternativly you can also mount the rad in one of the more forward mounting holes in the chassis legs to give you more clearance if you feel the standard twinky fans aren't up to scratch room wise
the sierra's were biult to such a random standardization that what may fit on one won't fit on another car, even though the shells are identical
Old Nov 1, 2011 | 10:32 PM
dojj's Avatar
dojj
Resident Wrestling Legend
those pics look like they were taken in my garden, i remember the rad, and the threaded rod, i might even have your spare one still lurking in the driveway
Old Nov 1, 2011 | 10:44 PM
mk22door's Avatar
mk22door
Wow, not really a lot ot go on, certainly not in my garden
Old Nov 1, 2011 | 11:12 PM
mick's Avatar
mick
the granny ones were done at yours the sierra rad was at your mums.....
Old Nov 2, 2011 | 08:28 AM
slider's Avatar
slider
I broke a Sierra with the boa in quite recently and they had used the standard a/c fan from the Sierra, worked perfectly and fitted easilh with loads of clearance, it was a g plate 2.9 4x4 originally
Old Nov 2, 2011 | 10:27 AM
Ade's Avatar
Ade
Fast Ford snapper
YB rad and fans on mine
Old Nov 2, 2011 | 06:12 PM
dojj's Avatar
dojj
The Granada rad fit but because it's a different shape you need longer bolts, as per the picture
Everything still fits too as the casing is the same other than the transmission cooler on the side
Old Nov 2, 2011 | 07:06 PM
D16PJM's Avatar
D16PJM
sorry couldn't resist.
Old Nov 3, 2011 | 11:04 PM
mk22door's Avatar
mk22door
Excellent, thanks to everyone.
Ade, how did you get the YB rad to fit? Are they not the same as the pinto sierra rad's? I mean I know it will fit the car but will the pipes match up with the joints on the rad?
Old Nov 3, 2011 | 11:09 PM
mick's Avatar
mick
i've seen people use cvh rads, the header is on the other side the same as the yb.
Old Nov 3, 2011 | 11:20 PM
robrs2's Avatar
robrs2
YB rad is just shorter so the intercooler can be fitted above.
Old Nov 4, 2011 | 01:49 AM
Ade's Avatar
Ade
Fast Ford snapper
Shorter and thicker rad'.... top hose is a universal flexi number
Old Nov 4, 2011 | 02:35 PM
mk22door's Avatar
mk22door
See, a thicker rad is probably not what I am after but thanks for the info, muchly greatly appreciato!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
