My 24v Sapphire Cosworth (UPDATE: Back OFF The Road)
Old Oct 30, 2011 | 07:56 PM
dojj's Avatar
dojj
Resident Wrestling Legend
or just click the link in my sig that says "quick shift" and some of the pics will explain stuff
the 2wd selector only has the 2 forward bolts and nothing at the rear (there is nothing to bolt onto) and the selector rod is fit in and clipped as opposed to round and fitted with the pin and spring
Old Oct 30, 2011 | 08:15 PM
skinnarbi's Avatar
skinnarbi
Tyres - It's What I Do
Cheers for the walkthrough dojj, I'll look at it in the morning, is the linkage still available from ford? Is it just a steel rod?
Old Oct 30, 2011 | 08:18 PM
dojj's Avatar
dojj
it's a steel rod with a bit on one end that goes to the bottom of the selector and a hooked pointy bit on the other than goes into the gearbox end
it's a very common failure point from what i can tell but seeing as there are plenty of 2wd mt75 boxes floating about the place, getting hold of a spare shouldn't be a problem
Old Oct 30, 2011 | 08:28 PM
skinnarbi's Avatar
skinnarbi
The reason I asked if it was steel is to see if it can be repaired as I need to get it sorted as soon as possible.
Thanks to Dojj everyone for their help and advice I really appreciate it so hopefully I can get it sorted tomorrow
Old Oct 30, 2011 | 08:32 PM
dojj's Avatar
dojj
you can weld it yes, but not sure if the bit thats broken would then foul the bits it needs to work within
and it also depends on where it's broken as well
or it oculd be the cradle that's bent which would spanner any work you were thinking of doing
Old Oct 31, 2011 | 10:09 PM
skinnarbi's Avatar
skinnarbi
Well after scrabbling around on the drive realised it just wasnt possible to do the job on stands. So the car has gone on a little holiday to a local garage called NDB who are a great and helpful bunch of guys, and they have managed to repair it for me.
In the mean time as a couple of people have asked me to post some, here are a couple of pics of the engine…
Should have the car back tomorrow all sorted
Old Nov 1, 2011 | 01:41 AM
mk22door's Avatar
mk22door
Fart of the Purniture
This is very nearly what I wanted to see.....
What fans do you have mate?
I am doing a 24v conversion on a saff, got some twican 8v sierra twin cooling fans as they fit the 24v radiator no problem ( I thought these were what everyone used), but you cant fit them as there too thick - catching on the pulleys!
Any chance of a description and photo of your clearence between the back of the fans and the pulleys?
Ken lowe fans a little out of my price range, but don't trust the cheap ebay slimline type fans.
Old Nov 1, 2011 | 01:53 AM
mk22door's Avatar
mk22door
Actually, just studying the second of your engine bay pictures, are they the twincam 8v Sierra fans?
Sure looks like the metal shrouding and the wires
Old Nov 1, 2011 | 08:43 AM
skinnarbi's Avatar
skinnarbi
I'm sure they are just the standard twink fans, although mine being based on a ghia used to have aircon so it does have a twin fan setup, if that changes the spacing at all. The fan on right (looking into the bay) doesn't work, it's seized up so I need to sort that. When I pick the car up later I'll take a picture of them and put it up.
Old Nov 1, 2011 | 11:31 AM
dojj's Avatar
dojj
Sized fans may work with a push but if it's seized properly it wil lead to a burnt fan loom which will have far more serious consequences
Old Nov 1, 2011 | 03:21 PM
mk22door's Avatar
mk22door
Originally Posted by dojj
not anything
Dojj, tell me what it is I need to do?
Old Nov 1, 2011 | 03:29 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
Originally Posted by Statey
Dojj what a legend!
+1 awsome .
Old Nov 1, 2011 | 09:10 PM
skinnarbi's Avatar
skinnarbi
Originally Posted by YOREVOL
+1 awsome .
+2
Thanks for all the advice mate
Picked the car up this evening, linkage is sorted so I can actually drive the car, but once fixed the garage found the box didn't like 2nd gear, it won't go in at low revs, you need to match the engine speed to get it in, so I think I'm right in assuming the syncro is shot on 2nd (correct me if I'm wrong) so I think a trip to my local transmission specialist and get him to check it out.
Old Nov 1, 2011 | 10:20 PM
dojj's Avatar
dojj
the fans are held in with 3 nuts/bolts and you simply undo the 2 securing bolts for the fan shroud, unplug the loom to the fans and pull it out
you can then mess about with it on the bench as the fans will more than likely have these threaded bits corroded
if the fan is siezed you can simply replace them and slot them back in again, almost the easiest thing to do on a sierra
apparently the diseasal fans used a slimmer shroud so you could always try and find them
alternativly you can also mount the rad in one of the more forward mounting holes in the chassis legs to give you more clearance if you feel the standard twinky fans aren't up to scratch room wise
the sierra's were biult to such a random standardization that what may fit on one won't fit on another car, even though the shells are identical
Old Nov 1, 2011 | 10:23 PM
dojj's Avatar
dojj
Originally Posted by skinnarbi
+2
1st/2nd gear syncro hub will be shot, it's not gripping the gear to slow it down as the brass bits have worn out from too much quick shifting
you will probably have felt the box not going into 2nd as fast as you would like as the boxes won't slow down fast enough to make the quick changes needed to get a good pull away from the lights, i used to find that my box would take longer to change from 1st to 2nd than it took to use up 1st
Old Nov 1, 2011 | 10:58 PM
skinnarbi's Avatar
skinnarbi
New box time or do you reckon it would be cheaper to get the box repaired?
Old Nov 2, 2011 | 11:30 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Fix the one you have, lot cheaper than finding two boxes and getting them made into a hybrid, only to find that you may still have a problem
Old Nov 3, 2011 | 07:59 PM
skinnarbi's Avatar
skinnarbi
Tiny update, took the box out today, just need to decide wether to get it rebuilt or just change it
Old Nov 3, 2011 | 08:10 PM
skinnarbi's Avatar
skinnarbi
Well my box is already a hybrid, so if I just buy a 4x4 mt75 and put my bell housing on it, that would work right?
Old Nov 3, 2011 | 08:17 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
No, because it would still be a 4x4 box.
Old Nov 3, 2011 | 08:36 PM
JohnnyB's Avatar
JohnnyB
find a twinky gear box and give it to a gear box man, should not cost you more than Ł100 to swap it, he needs to strip the boxes down that's why the cost.
Old Nov 3, 2011 | 08:38 PM
skinnarbi's Avatar
skinnarbi
How are these hybrid boxes made then?
Old Nov 3, 2011 | 08:52 PM
3FRD's Avatar
3FRD
I don't doubt that mate but it just looked like it had been abused for a while needed some TLC, if I was trailering it back it wouldve been a decent project, but driving it back 550 miles on 4 cylinders would not have been my most sensible of ideas haha
The blue Azura used to be mines, I sold it to the guy who owns it now about 6 months ago. It's not been looked after much since I sold it. I replaced the engine, box, wheels, front bumper, drivers seat, fuel pump, tank and loads of other bits on it. Was running A1 when he got it. I think the running problem is fuel pump related. It was a second hand group A pump that was put on it and I rewired it. Maybe a loose connection or the pumps no good. The guy who I got it from bought it from Wales with a rattly engine. He changed the engine and I ran with that engine for about 6 months, sold it to my mate who burst the radiator and trashed the engine hence why I put another one in it. Would have been a good project for you it was a solid shell with no welding.
Old Nov 3, 2011 | 08:53 PM
3FRD's Avatar
3FRD
I bought a Type 9 and used the bellhousing that was already on mines, it lasted pretty well and there cheap to replace, I have a guy up here who is a stock car racer, he has loads of them if you need one.
Old Nov 3, 2011 | 09:19 PM
skinnarbi's Avatar
skinnarbi
Was it you I was emailing about the blue one then? I was emailing one of the previous owners about it for a few days before it sold
Old Nov 3, 2011 | 09:32 PM
3FRD's Avatar
3FRD
Yeah it probably would have been. I've owned it twice and done alot of work to it. Shame if someone doesn't get it now and put it right. It was going that way before I got it back and fixed her up. Seems to be going that way again.
Old Nov 3, 2011 | 09:38 PM
skinnarbi's Avatar
skinnarbi
Stephen Morgan? It was ok, but just that running problem and the boot wouldnt open, the running issue could've been a simple fix, but I couldn't risk a 550 mile trip home with it not running 100percent
Old Nov 3, 2011 | 09:42 PM
3FRD's Avatar
3FRD
Yeah that's me.
The boot opened before not sure why it wouldn't open now. I'd guess it was fuel pump related, I sorted out alot of the dodgy wiring on it the 1st time around. It ran like a dog the last time the fuel pump went funny. Wouldn't start then would be ok for a while and then run like a dog again, was fine ever since I changed it. A new fuel pump would probably sort it.
Old Nov 3, 2011 | 09:50 PM
dojj's Avatar
dojj
you get a 2.9 4x4 v6 mt75 box and a standard rwd mt75 box
the front casing and input shaft from the 4wd box replaces the same on the rwd box
voila, hybrid box
edited to say that you will be looking at probably Ł300 all in to get teh box rebuilt like new, well, at least that what it used to cost me to remove, rebuild, refit and oil up my one
Old Nov 3, 2011 | 09:53 PM
skinnarbi's Avatar
skinnarbi
Is it possible to do it yourself or will I need specialist tools ect?
Old Nov 3, 2011 | 11:06 PM
robrs2's Avatar
robrs2
Yes tools and bearing pullers. But if you can find a diesel mt75 rwd box the its just the long socket you need for the input shaft. Then its just swap the front case half.
Old Nov 4, 2011 | 12:45 AM
skinnarbi's Avatar
skinnarbi
voila, hybrid box
Well I got a quote to have the box rebuilt, 462 quid and that's if I remove it myself which I already have. But I would rather do it myself
Old Nov 4, 2011 | 04:03 AM
robrs2's Avatar
robrs2
It cost me Ł140 plus vat to get my hybrid box parts swaped. A rebuild is far more.
Old Nov 4, 2011 | 11:26 PM
skinnarbi's Avatar
skinnarbi
Which clutch kit and thrust bearing is it best to use with this engine and box combo?
Old Nov 5, 2011 | 09:43 AM
chaffe's Avatar
chaffe
voila, hybrid box
its not that easy i did mine, have a look in my thread its well documented and pictured; Page three https://passionford.com/forum/restor...nd-mapped.html you have to totally strip both boxes
Old Nov 5, 2011 | 06:44 PM
skinnarbi's Avatar
skinnarbi
http://www.dcperformance.co.uk/cheap...dc9417pwr.html
Will this fit my car?
My current clutch plate is 242mm so I would assume it fits.
Is there a lightened fly wheel that will fit too?
Old Nov 5, 2011 | 08:28 PM
dojj's Avatar
dojj
it's the same clutch as the cosworth so no issues there
as for stripping the box, the front came off, i undid one bolt that holds the revere gear on the front casing, front comes off, big circlip and enough play to slide the front input shaft out and job done
looks like you've gone the whole hog and undone the big bolt in the back as well to remove it all, but it's been several years since i did mine so i may have forgotten how to change the selector stuff with it's little 10mm bolts but other than that i can't remember it taking longer than about 30 minutes apart and together again
Old Nov 5, 2011 | 11:10 PM
skinnarbi's Avatar
skinnarbi
Well we took the box apart at work today, figured if it was already broke what have I got to lose, everything seemed ok, all teeth were present and it went from one gear to the next no problem at all, so it must be a little mis-alignment in my repaired gear linkage, so we fixed that again, put the box back together and it seems to go through the gears no issues (albeit on a bench) so fingers crossed that's all it was. But the clutch and pressure plate are cooked. So I thought I may aswell change the clutch and put a decent one in while I'm at it.
Old Nov 7, 2011 | 11:41 PM
skinnarbi's Avatar
skinnarbi
Well the car is back on the road, box was all ok, turned out when the gear linkage was repaired it wasn't lined up properly hence it wasnt going into 2nd properly. So got a new clutch in, got one of my guys at work to repair the linkage properly this time (should've have done this the first time) drives great again
Old Nov 8, 2011 | 08:45 AM
chaffe's Avatar
chaffe
good stuff, now get it turboed! (you will need to take the box out again for a better clutch though lol)
