focus
Old Sep 17, 2011 | 09:07 PM
coolj's Avatar
coolj
Default focus
Hi I have a focus 1.6 on a 2001 plate and when u sit at tick over it goes up and down like its hunting its got a sports decat and strat thro exhurst systerm wod this make it do this and I have the normal alarm and its had another fitted I think they r working agaest each other because u unlock with the other alarm and it relockes itself u have to keep pressing it about three times then it stays unlocked so can anone help me plz
Old Sep 18, 2011 | 02:24 PM
coolj's Avatar
coolj
Can any one help me out plz
Old Sep 18, 2011 | 03:58 PM
martysmartie's Avatar
martysmartie
Assuming it's nothing to do with the car, i.e. it's not new, then check the vaccum hoses, they split, introducing an air leak.
Re the unlocking, it's a common problem that cars suffer, it sounds as if one of the "Masters is sticky", i.e. the driver or passenger door, when the C/L pulse times out, one of the motor is "Stuck in the middle" and so it simply reverts.
The remedy is to lubricate both locks.
Martin
Old Sep 18, 2011 | 04:37 PM
trev1964's Avatar
trev1964
Idle speed control valve....?
Old Sep 18, 2011 | 09:05 PM
coolj's Avatar
coolj
Were is it plz and wod it help to take pipes off and clean them and throtha body off and clean that
Old Sep 18, 2011 | 09:08 PM
coolj's Avatar
coolj
Martin
Thanks cud it not b the alarms working against each other at all iv got an old meta alarm they dnt make any more so mit rip it out and get rid of it
Old Sep 19, 2011 | 09:11 AM
martysmartie
ISCV is on front of engine, to the right of the inlet manifold, it has two bolts holding it and an electrical plug, be careful if you do remove though as you may need a new gasket.
Possibly, but it's normally the locks that cause this problem, but yes, I agree it's wise to remove it, can't see the point in having multiple systems!
Martin
Old Sep 19, 2011 | 01:21 PM
coolj's Avatar
coolj
Iv tok the iscv off and clean it and put it bk on and still the same now im confuesd with it and need help dnt no any think about cars really so can any one ealse help me plz
Old Sep 20, 2011 | 12:13 PM
coolj's Avatar
coolj
Martin
Wpt do u mean not new so the exhurst and decat wot not make it be hutting then and were r the air pipes that need checking and how can u tell if the iscv is working or not
Old Sep 20, 2011 | 12:22 PM
martysmartie
The valve is the sole control of idle, so yes it's working! They are known to get 'coked up' and so the operation is not smooth. In your case however I suspect an air leak.
What I meant by new, i.e. has it recently been fitted, so to eliminate this as a source of trouble.
The typical vacuum pipes are at the front by the PCV, there is a 'T' piece as well.
Martin
Old Sep 20, 2011 | 04:20 PM
coolj's Avatar
coolj
Martin
K&n has just bin fitted so now iv got to check air pipes for a leck and iv just change a thing on the sit of the carb to see if it woz that at all im lost of wot other things cud make it hunt
Old Sep 20, 2011 | 05:36 PM
martysmartie
You omitted that!
I would revert to the airbox, this could very well be causing this problem! Best thing you can do, is get rid of the induction cone, they do more harm than good on these cars, mainly due to the 'heat soak' they suffer from, so will do nothing other than create noise!
Also you are referring to the throttle body, these cars as with all modern cars do not have carburetter's.
Martin
Old Sep 20, 2011 | 07:24 PM
coolj's Avatar
coolj
You omitted that!
Martin
Bfor I put k&n on it woz hutting the bloke said it woz the sports decat I dnt think its the air filter as it did it bfoe I put it on its really doing my head in that iv not got a clue wot im doing or looking for
Old Sep 20, 2011 | 08:27 PM
martysmartie
Well as I said from the start it could be the sports cat, thats why I asked if it had been recently done and if the problem was evident afterwards.
I would check the vaccum hoses as I said as it does sound more like an air leak and it's something thats easy and free to do!
In any case the above still applies, the cone filter will only cause you problems, you are never going to gain any power, in fact maybe loose some due to the issue I mentioned already.
Best thing you can do is replace the filter with a new one, or the likes of a K&N panel filter.
Martin
Old Sep 20, 2011 | 08:52 PM
coolj's Avatar
coolj
How cud I find out if the sportss decat is the problem with out putting a normal one on there. And I will see if I can find a panel filter
Old Sep 20, 2011 | 09:01 PM
martysmartie
Check the pipes first as I say, for it to be hunting to me suggests an air leak, think simple, not deep
Martin
Old Sep 20, 2011 | 09:12 PM
coolj's Avatar
coolj
Wod resetting the ecu do,any think at all I just really want to fix the problem its doing my head in so im going to have a look tomorrpw even tho iv not got a clue were to look or wot to look for im no good with cars at all
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
