QUICK ANSWER NEEDED: Amal valve operation with ignition off?
Old Aug 21, 2011 | 09:29 PM
rog's Avatar
rog
Default QUICK ANSWER NEEDED: Amal valve operation with ignition off?
Is the Amal valve designed to hold pressure with the ignition off?
Seem to have a problem with boost and after hooking up a compressor the valve seems to vent to atmosphere around 18psi, is this normal?
Old Aug 22, 2011 | 08:27 AM
rog's Avatar
rog
Anyone???
Old Aug 22, 2011 | 02:28 PM
rog's Avatar
rog
I'm presuming it's buggered but would just like someone to
confirm please?
Old Aug 22, 2011 | 03:00 PM
BigErn's Avatar
BigErn
When you turn the ignition on to the the "reds" can you hear the amal valve click??
Old Aug 22, 2011 | 03:13 PM
rog's Avatar
rog
Yeah the solenoid clicks, I've tested it from
ignition and with a separate battery, so not doubt that's working but I wandered what it's off or 0v function was, it seems fine until 18psi then it pisses out air.
Old Aug 22, 2011 | 04:54 PM
cozmeister's Avatar
cozmeister
More boost Igor!
This think thread will help you - it helped me with a similar question: https://passionford.com/forum/genera...l-discuss.html
Old Aug 23, 2011 | 08:57 AM
rog's Avatar
rog
Thanks for the assistance lads, I swapped it last night and it works fine now, the valve just wouldn't hold pressure even though it was clicking as it should've been.
Old Aug 23, 2011 | 09:41 AM
BigErn's Avatar
BigErn
Nice to know it was an easy fix
Old Aug 23, 2011 | 09:57 AM
rog's Avatar
rog
Yeah too right, although it did involve a bit of head scratching as it appeared it was working ok, or atleast clicking, but as I found out that is only half the story!
S3an
Sep 26, 2015 11:39 PM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
cossirob
Sep 3, 2015 09:17 PM
