cosworth boost control.........discuss
whats my best option here
is the amal valve sufficient
i used to run a bleedvalve
would air injectors be a better option or an in car boost controller?
im not too clued up in this department
what do you need it to do?
air injectors are fantastic if you suffer from surge, as they are bleed on, so you can map the surge out by bleeding air to open the wastegate which slows the turbo stoping the surge,
they need to be live mapped though really
the amal valve in reality has very little control over your boost, tbh its wide open most of the time, if you looked at your amal valve table it would be full of "ff"
you can get aftermarket boost controllers that are bleed on, but they need a mapping session to sort them out.
what ecu do you run? can you not run a 12 position boost controller?
Air to air injectors will work with almost any ECU. As long as it has boost control tables it will generally be able to control an air to air.
Omex ECUs will run air to air no problem.
What about this?
Saw this set up on some of the turbocharged rallycross supercars, purely mechanical......
http://autospeed.com/cms/article.html?&A=0670
http://autospeed.com/cms/A_0685/article.html
i know 4k all about air injectors,i have asked but never told a real answer of when needing them,as for a bleed valve . . are you mad ? i wouldnt touch one of them with a barge pole even if i had a standard rst.i suspect your car is a lot more spent on/played tuned whatever,i still use amal valve but last time mine was rr it was only 310 so my post to you is totally useless i think,sorry.
With a decent(right) ecu you can control the boost perfectly, I have different boost levels on all three maps, vastly better control when letting off throttle as than some as a lot do not only boost against rpm but also against tps.
I have the std amal valve, never wanted air injectors, particularly when they fail you melt your engine, when an amal fails you just lose boost not your engine, I know which I prefer.
amal valve
the mad clicking as you refer to it as, is likely to be it switching due to a loose terminal or broken/damaged wire. either check the connections to terminals are on correctly and not corroded or replace the amal valve as the terminals have a habbit of becoming wobbly and losing contact. if you just want 2 stage boost control ie low and high a switch can be wired to the valve so for low boost the amal valve thinks engine is cold or too hot and for higher boost it is as normal/high boost
to know for sure if this is the problem with your drop in power just unplug it and this will be low boost if no change in boost pressure then you know its your problem
cheers Chris
cheers Chris
It's just that some set-ups fail "safe" (meaning only actuator boost pressure), where if air-injectors fail, you get no boost control and you effectively have unlimited boost. However, you can set everything up, so that in this form your "unlimited" boost is the peak boost anyway. Mine has been done this way, so that if I disconnect the air injectors, I have no boost control, but 2.2 bar fixed.
Obviously if you don't have these set up like this, then it does have the potential to melt the engine, but only if you are a complete numpty, as 1. You should have a gauge that when this happens, it will be obvious with the first press of the throttle when the boost gauge shoots past it's normal peak. 2. If you don't have a gauge, then the car will certainly feel VERY different. The induction noise will be drastically increased and the car will suddenly (and briefly ) feel MUCH faster than normal. If you ignore these signs, you're a fucking numpty anyway .
In theory that would be best, and you could certainly do it if the engine had not been mapped beyond the limits of the map sensor. However, in Cossie tuning, people tend to go a fraction beyond the 3 bar's limits and extrapolate the fuelling etc. Not ideal, but precludes a boost limit on these set-ups (especially with a large turbo's tendancy to briefly over-shoot).
i know i've had a problem where the pipe that goes from the amal to the compressor house came off and the turbo just kept making boost - i knew there was something wrong as my boost went off the dial
cheers Chris
cheers Chris
The other reason the amal valve will click its nuts off will be if there's too much preload on the actuator - at least that's what I found when i attached a working one to my Saff. I'd manually adjusted the actuator to deliver 15psi, but had no idea the amal valve was dead. As soon as I spanked it in 2nd with a working amal valve, the needle on the boost gauge nearly snapped off as it bounced of 30psi, while I, ever the stiff upper lipped type, spunked in my pants, and shit myself as it hit Warp Factor 9. Suffice to say, the rod's a little longer now, and I'm a little wiser.
It does.
Chris tried to compensate though, as he wound the actuator up to it's limit so that it gave 15psi with a NON-working AMAL valve, so as soon as he put a working one one - warp factor 9 and 30psi, as it was then doing what it should, so he got silly boost .
CabrioTurbo
01-08-2015 12:04 PM
Escortdriver1
31-07-2015 03:36 PM
