cosworth fuel pump
Old Aug 3, 2011 | 05:27 AM
loonychippy's Avatar
loonychippy
Default cosworth fuel pump
putting a new pump on my sapphire cosworth ,can anyone tell which colour wire to black terminal on pump .got a black wire with red trace and brown wire .want to get it fired up and driven after 15years parked in my garage
cheeRS
gary
Old Aug 3, 2011 | 05:35 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
I would seriously put new fuel pump wiring in if its been sitting for 15 years and a new fuel filter (still available from ford).
Buy a 30 amp relay, red and black 17 amp wire and ring crimps for the pump and battery conections from Halfords.
Take the red wire from the battery to the relay, find the fuel pump wiring which should be behind the left boot carpet and find the (black and red stripped IIRC) ignition wire for the pump, and use that wire for the relay's ignition connection and simply earth the relay and pump to the little bulkhead behind the boots carpet. Flick through my cars thread (link below) to find a few photo's when Richie and I did it to my Saph.
Hope this helps mate and good luck with the start up.
https://passionford.com/forum/ford-s...ml#post4269460
Motorsport Development's do new wiring for fuel pumps too. Give Stu@Motorsportdevelopments on here a shout. They are good.
http://www.shop.motorsport-developme...044-1011-p.asp
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
