cosworth 200blocks
Old Jul 29, 2011 | 08:53 PM
Trist's Avatar
Trist
Default cosworth 200blocks
what were they in? was it just a cosworth block? are there shite weak ones around, I heard they used a weak 200 block in the transit??
Old Jul 29, 2011 | 08:55 PM
DAN400's Avatar
DAN400
transits had 205 and 202 blocks
Old Jul 29, 2011 | 09:05 PM
Trist's Avatar
Trist
is it? 200- 4x4 and 205- 2wd 200 is the better block? how is it stronger?
sorry for questions. just want to be sure what i am saying.
Old Jul 29, 2011 | 09:15 PM
DAN400's Avatar
DAN400
yes 200 is stronger , they came in the 4wd cars, you can long stud a 200 block , but not a 205 or 202 block.
Old Jul 29, 2011 | 09:36 PM
Trist's Avatar
Trist
didnt know that cheers.
botters's Avatar
botters
competant bodger
200 is a thicker block that was made stiffer for the strains of the 4x4 having a diff bolted to the sump, the rs 500 had a 200 block allthough this had smaller core plugs which give it slightly more strength
Old Jul 29, 2011 | 09:43 PM
escort700bhp's Avatar
escort700bhp
rs500 has 205 block,different casting material with small core plug
Old Jul 30, 2011 | 07:52 AM
Core plug is zero to do with strength, the small core RS500 block(205based) used a slightly different casting mix.
There are numerous other pinto blocks available, apart from 200/202/205, maybe not in this country, but I'm sure the 197 was used over here.
Old Jul 30, 2011 | 09:13 PM
martysmartie's Avatar
martysmartie
200 is only avaliable in 4x4/Escos models, it is a stronger block than the 205. Part of the reason it was used due to the transmission stress of the 4x4 models.
I'm sure there is no such thing as a 197, the number merely denotes the capacity i.e the 20, the 5 denotes 1985 which is the year when the block was revised, the 0 in 200 means 1990 and so on.
The 202 block was indeed a Transit block but it isn't as strong as a 200.
Before such times the block was simply a 20 or T88 block.
In the same way you can have a 165 block but obviously a 1600 Pinto.
Martin
Old Aug 1, 2011 | 07:11 PM
Cossiemainful's Avatar
Cossiemainful
As far as I know:
2WD = 205
RS500 = 205 (bit stronger as the standard 2WD 205)
4WD = 200 (the strongest of all blocks and best for tuning basis)
Old Aug 1, 2011 | 09:24 PM
martysmartie
Originally Posted by Cossiemainful
As far as I know:
2WD = 205
The RS500 "205" IIRC was actually a little loop hole in the design process and was made specifically for the 500, it's just they kept the designation number the same, it's actually a different cast as said and is much stronger than the 205 (They had to be for the power they run).
Martin
Old Aug 2, 2011 | 07:49 PM
Cossiemainful
Thx for info m8. Is my assumption correct that the 200 block is the strongest of all? At first I thought the RS500 was the strongest.
Old Aug 2, 2011 | 08:29 PM
J1mbo's Avatar
J1mbo
B1mbo
The rs500 205 block can be long studded unlike 205 normal blocks, rs500 is I understand basically a 200 block
Old Aug 3, 2011 | 09:17 PM
Trist's Avatar
Trist
is there anyway that determins a RS500 205block from 2wd 205block?
Old Aug 3, 2011 | 09:23 PM
martysmartie
Yes it should have YBD cast into the block by the water pump I should think, a normal "Cosworth" 205 will have YBB followed by a number. Also YBD (RS500) 205 has smaller core plugs as well.
Martin
Old Aug 3, 2011 | 09:30 PM
J1mbo's Avatar
J1mbo
B1mbo
As above trist, just the small core plugs is the easiest and quickest way! They're very small compared to normal
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
