SAPPH BOOST PROBLEM
Old Feb 12, 2005 | 10:27 PM
tosh's Avatar
tosh
Default SAPPH BOOST PROBLEM
went for a drive today and noticed what I think is a boost problem, I was poodleing along at 65 mph in 5th gear then nailed the throttle and just before it started to boost it died before I could hit 70 mph, until I released the throttle again.
It only seems happen in that rev band and in 5th
Any idea as to what this could be ? and what I need to check
chears
Old Feb 13, 2005 | 12:04 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sounds like overboost protection due to running too much boost.
Was the cut severe? Like someone turned off the ignition?
Old Feb 13, 2005 | 12:24 PM
tosh's Avatar
tosh
Yes thats exactly what it felt like, "totaly die's" is there anything I can check myself,
thanks
Old Feb 13, 2005 | 02:51 PM
john_p_b's Avatar
john_p_b
i thought i was special having this problem when i got my sapphire a few weeks back but after reading the tech sections on here and rsoc it seems my car is just common with it's illness's
Old Feb 13, 2005 | 03:35 PM
Nik_W's Avatar
Nik_W
I had that problem after adding stage 3 parts. It wouldn;t run smoothly over 18psi, anything higher it would cut out slightly then go again. After a lengthy check over everything it turned out to be a corroded dizzy cap, that wasn't producing a strong enough spark.
Old Feb 13, 2005 | 03:44 PM
john_p_b's Avatar
john_p_b
mine was over boosting (as stu directed me to at the time!) simple adjustment to the actuator later and all was fine
JK12
33
Apr 26, 2021 12:09 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
