Jumpy Speedo needle on mk4 Escort
Old Jun 6, 2011 | 10:43 PM
Dennis_Wiseman's Avatar
Dennis_Wiseman
Default Jumpy Speedo needle on mk4 Escort
Read that this is usually the cable which causes the needle to fluctuate and bounce so replaced the cable but its still not sorted it.
Does anyone have any other suggestions what could cause it?
When im not on throttle the speedo needle drops right down, when i come on the gas it goes to nearish the speed but a bit bouncy
Old Jun 7, 2011 | 05:45 PM
Have the numbers peeled off the dial face, this happens on mk4 escorts and causes many issues with sticky sluggish needle movement.
Old Jun 8, 2011 | 06:12 PM
wing's Avatar
wing
could be worn speedo drive or diff bearings
Old Jun 12, 2011 | 07:49 AM
Dennis_Wiseman
No their mint. I know what you mean tho. Most are like that in my local breakers.
Think i'll oil the speedo drive gears and see if that helps
Old Apr 18, 2012 | 07:35 PM
adampotten's Avatar
adampotten
1.3 POPULAR
Did this fix your problem as my escort has started doing this. if so how did you go about oiling the gear and what sort of oil did you use
thanks Adz
Old Apr 18, 2012 | 08:11 PM
GVK.'s Avatar
GVK.
It's normally worn diff bearings causing this, have a look under the car and see if you can 'rock' the inner drive shaft joints up/down, (try to rock both shafts at the same time) and see if there's any oil leaks from the drive shaft seals.
Old Apr 18, 2012 | 08:51 PM
TOOTALL's Avatar
TOOTALL
Sorry to but in..........but my mk6 rs2000 has started doing this. Same sort of cause?
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
markk
Sep 9, 2015 08:11 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Adam Graham
Sep 6, 2015 06:04 AM
Bighandsuk
Sep 2, 2015 05:23 PM
