Throttle bodies
Old Jun 5, 2011 | 09:56 AM
woolford's Avatar
woolford
Default Throttle bodies
What is the easiest and best set to convert to fit a 2.0l blacktop zetec??
Thanks
Old Jun 5, 2011 | 11:29 AM
mobb-black's Avatar
mobb-black
Get a kit from weber alpha or jenvey. Put it on and take it to somewhere like motorsport developments to get it mapped.
Old Jun 5, 2011 | 11:43 AM
woolford's Avatar
woolford
Didn't realty wNt to spend £1000+ on them seen someone on here had done some
Old Jun 5, 2011 | 12:30 PM
ChrisH's Avatar
ChrisH
If you want to do it on the cheap bolt a pair of Weber 45 carburettors on it with a low pressure fuel pump (about 4.5 PSI) and do away with the injection wiring and just use the ECU for sparks. Take it to a rolling road to get it jetted and choked correctly, be about 500 quid (ish)
Old Jun 5, 2011 | 12:37 PM
woolford's Avatar
woolford
Reason I want to maybe do bike throttle bodies is I should see 200bhp with them it just a thought.
Old Jun 5, 2011 | 12:46 PM
ChrisH's Avatar
ChrisH
If it's the 143 Brake model you wouldn't see 200 with throttle bodies, maybe 170 but then you need cams to reach full performance of the throttle bodies.
Old Jun 5, 2011 | 01:52 PM
woolford's Avatar
woolford
its a 2000 2.0l blacktop raised comp fast road cams uprated valve springs st170 manifold and ss exhaust internals all balanced with light weight fly wheel
Old Jun 5, 2011 | 02:00 PM
mobb-black's Avatar
mobb-black
CARBS DONT GO THRU AN MOT!!!!!!!!! Jesus. It won't pass emissions on a car that was originally fitted with fuel injection. And the spark won't advance or retard correctly if you simply hack out half the loom.
On the cheap use bike throttle bodies and megasquirt and get a manifold from bogg bros.
As an aside, if you have thousands of pounds worth of engine why are scrimping on the most important part of the engine.
Old Jun 5, 2011 | 03:19 PM
ChrisH's Avatar
ChrisH
I've replied to this in the other thread. However, fuel and spark are two completely different things.
Timing and spark duration times can adjusted across the RPM range. Additionally, timing advance will be calculated for a variety of inputs including increasing RPM vs. decreasing RPM (braking, coasting, or accelerating), throttle position, temperature, altitude, etc. The ECU is still controlling sparks therefore the timing.
Old Jun 5, 2011 | 10:52 PM
woolford's Avatar
woolford
So it's going to cost more than I care to spend getting it right
Old Jun 5, 2011 | 11:29 PM
ChrisH's Avatar
ChrisH
Well it's a minimum of 500 quid just for the mapping, it's very time consuming. You'll be looking at 1k on the cheap.
Old Jun 6, 2011 | 09:33 AM
woolford's Avatar
woolford
Can't be arsed spending another grand on it
Old Jun 6, 2011 | 11:13 AM
ChrisH's Avatar
ChrisH
May be a lot of money but it will give you a lot more performance and your cams now have the full potential they were designed for.
Old Jun 6, 2011 | 05:25 PM
woolford's Avatar
woolford
Maybe just a larger throttle boddie. I have heard a jag throttle bodi fit but which one??
Old Jun 6, 2011 | 07:17 PM
ChrisH's Avatar
ChrisH
The OEM manifold will restrict it.
Old Jun 6, 2011 | 08:41 PM
Churtz's Avatar
Churtz
A few people have gone the route of GSXR750 TB's, megasquirt v3 ecu, an map it yourself and seen some very impressive results.
I've seen it done for £500 all in!
Matt
Old Jun 6, 2011 | 08:43 PM
ChrisH's Avatar
ChrisH
Surely they must have done it themselves then? Or put a base map on it.
Old Jun 6, 2011 | 08:55 PM
Churtz's Avatar
Churtz
Just about any ecu that you buy will carry a base map to get you running. There is an MS dealer near Bristol that did an ecu and map for £300. Can't remember their name.
But the zetec throttle bodied approach is done by sooooo many kit car peeps there are loadsa maps to choose that will see good power.
I've mapped megasquirt myself and it's really not too hard with a wideband lambda.
Matt
Old Jun 6, 2011 | 09:37 PM
ChrisH's Avatar
ChrisH
Matt
I've never done a megasquirt before, i just heard that they're not very nice. We use DTA a lot, first time i looked at it i didn't know what i was looking at, used to it now, we mapped a full race ST170 using a laptop lol.
Old Jun 7, 2011 | 02:22 PM
mobb-black's Avatar
mobb-black
Churtz : A few people have gone the route of GSXR750 TB's, megasquirt v3 ecu, an map it yourself and seen some very impressive results.
Churtz I said this further up. These two are in their own world, I'd leave them to it if I were you.
Old Jun 7, 2011 | 02:25 PM
ChrisH's Avatar
ChrisH
Apart from it's Churtz and I having the conversation?
Old Jun 21, 2011 | 09:27 PM
slydawg65's Avatar
slydawg65
ive a set of GSXR750 throttle bodies and a dunnell zetec manifold with injectors here. £160 lifts the lot..
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
