Rs1800 Zetec sensor locations
Old May 30, 2011 | 04:01 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default Rs1800 Zetec sensor locations
Hi, I need to nkow the sensor locations of the following if any one knows.
ECU coolant temp sensor
Temp gauge sensor
Fan switch
Im thinking the small one in bottom of the stat housing is the CTS
The big chunky one in the top of the stat housing is the temp gauge
And the big chunky one in the drivers side of the rad is the fan switch
CheeRS for any help
Brian.
Old May 31, 2011 | 09:29 PM
ChrisH's Avatar
ChrisH
Fan switch is on the side of the rad. CTS is on top of the thermostat housing and the gauge sender is on the bottom of the thermostat housing.
DixieTheKid
11
Jun 6, 2020 11:20 AM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
Brian
Sep 11, 2015 08:06 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
