help me please !!!!!!big problem
Old Apr 18, 2011 | 06:25 PM
puma donna's Avatar
puma donna
Exclamation help me please !!!!!!big problem
hi ...i have a ford puma millenium 50.000 miles and something has gone drasticaly wrong with her..
i was driving back from the market and huge rotating banging noise started coming from the engine, my partner has jacked the car up and on inspection
when the wheel is rotated the engine is moving with it , and he says the drive shaft is knocking the engine, he is totally lost as to what has gone wrong as the drive shaft and joints etc seem to be ok
he has disconnected the bottom arm to pull the shaft out of the half shaft housing
and he has no clue other than when the shaft is slightly pulled out of the housing and rotated the engine does not move ....
any help would be appreciated as ive got the feeling this could be an expensive fix .. thanks in advance
Old Apr 18, 2011 | 06:29 PM
nugnah's Avatar
nugnah
have you started the engine with the car not moving
jas
Old Apr 18, 2011 | 06:34 PM
puma donna's Avatar
puma donna
yes ....thanks for replying
dojj's Avatar
dojj
Resident Wrestling Legend
sounds like the clutch/gearbox has broken and it's welded the input shaft of the box to the end of the crankshaft
happened to me on my sierra and it took several attempts to jump on the gearbox with all the bolts undone before it split from the engine
both were out of the car and on the deck so we had plenty of run up
or it could be something as simple as the clutch has gone bang and one of the springs has snagged on the flywheel
pull the starter out first to see if you can spot any obvious damage
Old Apr 18, 2011 | 06:35 PM
nugnah's Avatar
nugnah
are there any nosies when you run the engine without moving
jas
Old Apr 18, 2011 | 06:38 PM
puma donna's Avatar
puma donna
the engine is fine and still drives ok its just when the wheels rotate the engine moves and after a rotation of the wheel the engine rests back to where it started it moves when the drive shaft turns probably about 10-15mm
ohh and the half shaft oil seal has subsequently shared the gear oil with the road
i can add info u may think will help
Old Apr 18, 2011 | 06:44 PM
puma donna's Avatar
puma donna
any help before the garage has my pants down literaly...
Old Apr 18, 2011 | 06:46 PM
dojj's Avatar
dojj
sounds like you've broken an engine mount then
nowhere near as serious
Old Apr 18, 2011 | 06:47 PM
dojj's Avatar
dojj
put everything back together again and then, with the engine running but the bonnet up, slowly release the clutch pedal to the biting point and see if the engine rocks back and forth when it reaches that point
Old Apr 18, 2011 | 06:50 PM
puma donna's Avatar
puma donna
hi i just tried that today and it does move quite abit
infact cos its completely of the floor at the moment i stuck it in 1st and threw my foot off the clutch and it jumps around quite a bit , but the mountings look ok nothing visualy broken, that i cant tell anyway..
Old Apr 18, 2011 | 06:51 PM
trev1964's Avatar
trev1964
Sounds like cv joint to me...
Collapsed....?
Cossy Mike's Avatar
Cossy Mike
As above put it in gear and try and pull away in 3rd with the handbrake on.
Watch through the gap in the bonnet and see how high the engine will lift/knock.
Old Apr 18, 2011 | 06:53 PM
puma donna's Avatar
puma donna
hi trev thats what my fella said at first but he said there would be allsorts of noises and stuff coming from that area which there isnt ..
Old Apr 18, 2011 | 06:55 PM
puma donna's Avatar
puma donna
ahhh so i need to be resting on all fours to check if the mounts have buggered
Old Apr 18, 2011 | 06:56 PM
puma donna's Avatar
puma donna
if the conclusion is that the mounts have gone ... how hard a job is it to change them ?
is it diy material or not
Old Apr 18, 2011 | 07:01 PM
steves24V's's Avatar
steves24V's
Collapsed....?
Just what I was thinking, we had a fiesta at work do that, you'd turn the wheel and it would go passed a tight spot and as it was the engine was getting pusted 20mm+ over to one side.
Can you turn one wheel ok. (front)
Old Apr 18, 2011 | 07:03 PM
puma donna's Avatar
puma donna
thats exactly whats happening
one side is fine the other has resistance till u get to a point then the wheeel springs round and the engine moves at the same time
was it the mounts steve 24vs
Old Apr 18, 2011 | 07:13 PM
steves24V's
no it was the inner drive shaft joint, which side is yours doing it, ours was the passanger side we put a recon drive shaft on.
Old Apr 18, 2011 | 07:22 PM
puma donna's Avatar
puma donna
its the drivers side the one with the half shaft ..
so u mean the cv joint at the wheel hub
would i be able to tell by eye if i took the boot off and all the grease out
would it really push the engine if collapsed there was no strange sound before it happened it just went..?
Old Apr 18, 2011 | 07:24 PM
Cossy Mike's Avatar
Cossy Mike
Sounds like cv joint or driveshaft fault if it has resistance on the wheel rotation......engine mount would no way effect the wheel rotation
Mount is just a bit awkward to change, need an engine hoist or something to support engine or to lift block an inch to get old one out.
Old Apr 18, 2011 | 07:27 PM
Cossy Mike's Avatar
Cossy Mike
Yeah you should if you de grease it. Check for chewed up metal........
If one side is turning freely and the other is'nt yeah it would not balance evenly so would rock on one side causing a slight lift....
Old Apr 18, 2011 | 07:29 PM
puma donna's Avatar
puma donna
i cant get my head round it
my partner says the resistance is from the outer shaft touching the back of the half shaft socket (as though the engine is leaning on it)
or as u say if the cv is chewed up it would not be sat properly
Old Apr 18, 2011 | 07:31 PM
steves24V's
ours was the inner cv joint part had broken up and got stuck in the end of the joint so the bearing parts couldn't side in the joint properly, when you turn it see if the shalft is staying in the middle of the joint and not going round like a spiral, ( if you get what I mean )
Had that bottom ball joint been out for any other work before it happen,
I'd money on it, its the of the drivers cv joints if thats the side the goes tight when turned.
Old Apr 18, 2011 | 07:33 PM
Cossy Mike's Avatar
Cossy Mike
That sounds very possible but surely by looking at the engine block you'll see if it's not sitting even?
Very much sounds like the cv joint has collapsed and the circlip is still trying to hold it all together
Old Apr 18, 2011 | 07:38 PM
puma donna's Avatar
puma donna
the shaft was removed from the half shaft socket and the three bearings on the end of the shaft that slide were all fine and dandy
and it didnt spiral when checked just pushes right to the back of the socket and moves the engine (and thats with the wheels off the ground ,
im guessing it will only be worse when on the floor and the suspension goes up and she shaft pushes further in the socket ..?
i may have to do some more investigation tommorow after work now i have an idea what im looking for
Old Apr 18, 2011 | 07:50 PM
puma donna's Avatar
puma donna
just been out to look at how the engine is sat
and it does lean back to the bulkhead quite a bit but i dont have another puma to compare it to would anyone beable to tell from a photo ..?
Old Apr 18, 2011 | 07:55 PM
Cossy Mike's Avatar
Cossy Mike
Can you not look at the stress on the opposite engine mount? they should be equal
Old Apr 18, 2011 | 08:01 PM
puma donna's Avatar
puma donna
its hard to tell as the right mount is a different type to the left and hidden under the battery tray
Old Apr 18, 2011 | 08:06 PM
puma donna's Avatar
puma donna
i think the plan is to degrease the outer cv joint and check it out to see if it is foooked then take it from there
ill update tomoz with good or bad news or just to bash your heads some more...lol
thanks ever so much everyone for taking time to help its very much appreciated ...top site
Old Apr 19, 2011 | 07:22 PM
puma donna's Avatar
puma donna
Exclamation re ~~ update~~
ive just had the drive shaft and cv joint out and dismantled them and all are in perfect nick so that is eliminated ...
so is it likely to be the mounts then ?
could it be any other problem before it goes to the garage ..?
Old Apr 24, 2011 | 03:02 AM
landamalta's Avatar
landamalta
check the wishbones in my fiesta i had the rubber bushes in the wishbones faulty (they took an oil bath and got chewed) so when i steered the the shaft was pushed inside the cv joint and it made a loud noise and created resistance for the wheel to turn.... I didn t take care of it and ended up with a ruined CV joint and finally i couldn t reverse cause the shaft would slip inside the cv joint. so whatever it is do not risk like I did cause the cost will only increase
turbotrev
14
Sep 27, 2015 10:44 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
