What PSI?
Old Mar 29, 2004 | 05:49 PM
Default What PSI?
Whats the lowest and highest psi a stage 3 turbo can run safely? (approx)
Old Mar 29, 2004 | 06:19 PM
Guinnless's Avatar
Guinnless
Err you might need to supply some more info than that....
Old Mar 29, 2004 | 06:24 PM
Its for my ERST2 i need a new turbo and just wondered if a stage 3 could be fitted so i can add other mods as i go along without changing turbos.
Old Mar 30, 2004 | 06:22 PM
Guinnless's Avatar
Guinnless
You are better off matching turbo to engine. Stage 3 turbo could mean anything.
Speak to a tuner with your exact engine spec and requirements.
Old Mar 31, 2004 | 04:19 PM
Cheers mate have done and i'm getting a stage2 turbo from turbo technics this weekend
Old Apr 5, 2004 | 11:20 PM
Rick's Avatar
Rick
not about the boost mate - depends on the rest of the engine
Old Apr 9, 2004 | 03:31 PM
so it wouldnt be a good idea then to buy a stage three when all ya got is pace intercooler,xzorst,filter?
what else would i have to do to make it worthy of fitting say a stage 3 turbo!
Old Apr 13, 2004 | 01:42 PM
CabrioTurbo's Avatar
CabrioTurbo
Dependant on the boost you were running it could be very laggy IIRC the stage 2 turbo from turbo technics still retains the original ex housing hence making it spool up quick.
to warrant a 'stage 3' turbo (ie .48 housing or bigger) then you will need over 18/20 Psi of boost.. Which isnt going to be much use if the car has a standard head etc on it.
CheeRs
Phil
timsrs
Nov 13, 2018 11:48 AM
dombanks
Sep 21, 2015 08:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
Marino
Sep 12, 2015 11:10 AM
