jerky xr2i!!!!!
Old Feb 1, 2005 | 03:47 PM
bigjim's Avatar
bigjim
Default jerky xr2i!!!!!
this is driving me mad. its been doing it since i bought it a few months back. when at low speeds or low rpm i can feel the car jerking slightly back and forward, usually around 2-3000rpm in any gear. no problem under full throttle and it doesnt do it when its not in gear. took it to respected specialist garage who did full diagnostic check and set it up said the fuelling was out. it has been a bit better since then but its still doing it and it is really doing my head in. should i try changing leads and plugs? car is totally standard by the way. anyone any ideas?
Old Feb 1, 2005 | 05:10 PM
K18NEO's Avatar
K18NEO
could be your map sensor, exhaust sensor telling your ecu your emisions are out cuz its gone, or piston rings have gone, i think that was the 3 things that was the problem or 1 of them was... hope it helps.
Old Feb 2, 2005 | 08:42 PM
k1gsxr750's Avatar
k1gsxr750
i have just got rid of a xr3i 1990 efi which did the same thing and i changed everything (and i meen everything) i could think of i still could not cure it i dont think you can cure it its something with the efi engine i hate that engine never again will i have one
my advise is save your money and dont even bother to try to fix it
Old Feb 3, 2005 | 10:45 AM
Chuckboost's Avatar
Chuckboost
Make sure all of off the breather pipes and oil cannister are clear from crap, had a problem like this a few month back cleared the fault
Cheers Chuck
Old Feb 6, 2005 | 01:08 PM
GTechR's Avatar
GTechR
Have you cleaned the ISCV? they get all gummed up and dont work properly... the end result is similar to your description.
Old May 7, 2011 | 01:50 PM
HirenRS's Avatar
HirenRS
turbovh
i had the same prob jus tied a zip tie over the edis to make the connectionbetter worked treat
took the zip tie off now and the car doin it over again
Old May 7, 2011 | 04:51 PM
As eluded to above, it sounds as though the ignition timing is changing with all else being correct, if the edis module has a ignition map in it, and uses a vac pipe this can certainly cause what you have.
Andypandy260
Sep 23, 2015 10:28 PM
bigjim
Fiesta RS1800/RS Turbo
Jun 4, 2005 02:08 PM
bigjim
Nov 17, 2004 12:51 AM
fiesta_xr2i_guy
33
Oct 27, 2004 09:09 PM
lil rst boi
Aug 17, 2004 03:41 PM
