FRST Boost problems
Old Mar 29, 2004 | 02:19 PM
Default FRST Boost problems
Wen i boost in any gear it seems to cut power at 0.4 bar. This happened wen i run low on petrol 2 weeks ago but now having a full tank of the stuff, it is happening again!
The amal valve has alreaady been taken off cause it didnt work wen i bought the car.
got a bleed valve on at the mo n set as close to standard boost as poss using a boost guage.
The car hasnt been chiped. and is runnig a standard turbo
Could this be due to fuel filter, pump or could it be somthing else.
Old Mar 31, 2004 | 04:50 PM
I had the same problem with my Orion RST. Mine is chipped and does this when it's low on petrol.
But once I had this problem because of the fuel filter. And another time happened when I i ncreased the boost. If you increase the boost the spark plugs' gap has to be increased accordingly. Check also if you need to change the spark plugs.
Hope this will help
Old Apr 5, 2004 | 08:10 PM
L33 BYT's Avatar
L33 BYT
seen this on s2. Check your boos hoses are not collapsing when under boost. also check your actuater is A.OK
JK12
33
Apr 26, 2021 12:09 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
