mk4 xr3i cabriolet starting issues HELP!!
Old Jan 17, 2011 | 03:54 PM
whywontyoustart1983's Avatar
whywontyoustart1983
Default mk4 xr3i cabriolet starting issues HELP!!
HI I HAVE A MK4 XR3I CABBIE WITH EFI ENGINE.....
A FW MONTHS BACK THE CAR WAS RUNNING THEN SUDDENLY JUST CONKED OUT AND GAVE UP.....
ON TURNING THE IGNITION WE FOUND THE CAR HAD NO SPARK......CHECKING EVERYTHING WE ESTABLISHED IT COULD BE THE COIL PACK............IT WASNT.........HAVE BEEN TOLD IT MAY BE THE CRANK SENSOR BUT CANT SEEM TO FIND ONE ON THE CAR..............
ANY HELP WILL BE MASSIVLEY APPRECIATED BEFORE I END UP LOSING MY RAG AND BEATING THE CAR WITH A BRANCH FAULTY TOWERS STYLE
CHEERS
WAYNE
Old Jan 17, 2011 | 05:27 PM
Northants Ford Fan's Avatar
Northants Ford Fan
the crank sensor should be on just above the starter motor held in with a small torque bolt
Old Jan 17, 2011 | 09:05 PM
whywontyoustart1983
not there mate, looked all over
Old Jan 19, 2011 | 05:03 PM
Rogeyboy's Avatar
Rogeyboy
Crank sensor will be in the block, look behind the exhaust manifold/downpipe over to the gearbox side of the block, it'll have a wire going into it.
It must have one for the ECU to register the engine turning over and therefore producing a spark!
Old Jan 19, 2011 | 05:51 PM
JonathanJ's Avatar
JonathanJ
As said before , must have a crank sensor if EFI , have a look at my location , pm me if you wish and we can have a chat by phone if easier
Old Jan 19, 2011 | 09:38 PM
whywontyoustart1983
are you sure somebody told me crank sensrs were only fitted from 1990 onwards.......going have a look again tomorrow will keep ya informed..............sorry but i clueless and so is everyone else who has come to look at the car
Old Jan 19, 2011 | 11:10 PM
Adamkelly's Avatar
Adamkelly
just a tought,
does it get feul. as there is a fuel cut out in the boot under the tyre.
just press the white butten in.
Safty for crashes ect, might also cut sparks but not sure...
Old Jan 20, 2011 | 04:58 PM
JonathanJ's Avatar
JonathanJ
If you want me to come and look at car then i will as just down the road , see my pm
Dahl88
Aug 22, 2015 08:16 PM
Bailes1992
Aug 16, 2015 07:14 PM
Red_bull
Aug 9, 2015 08:34 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
