Distributer ....
Old Jan 13, 2011 | 07:56 PM
2wd's Avatar
2wd
Default Distributer ....
Hey ... can anyone tell me how much "slip" there is allowed in a Distributer axel ? As it is on mine I can move the axel so that the distributer shaft cam lobes almost hits the phase sensor witch makes it impossible to adjust ?? That cant be good
Please advice
Old Jan 14, 2011 | 05:55 AM
2wd's Avatar
2wd
Noone knows ????
Old Jan 14, 2011 | 06:34 AM
Chaz888's Avatar
Chaz888
most of the diz cars I have had the tolerance on diz parts is very small sounds like it needs a overhall .
Old Jan 14, 2011 | 06:52 AM
2wd's Avatar
2wd
Overhall ... is that possible .... or should I get a new one if possible ?
Old Jan 14, 2011 | 04:14 PM
It's fooked basically, there should be NO play felt let alone seen, it will get worse, it is caused by the top bush sticking to the dizzy shaft and spinning inside the aluminium body.
The bushes are not great, they are made from compacted crushed iron particles, the good news though is there is a cure, this costs Ł35, but will outlast the car, it is to machine true the spindle and fit a oil lite bush, these are self lubing, and will give you zero problems.
This is also what I did to my one, and a few other people's, been perfect, have used this material for years, since seeing a mate use it on his custom made minature steam engines he makes for people as a business.
Old Jan 14, 2011 | 09:26 PM
2wd's Avatar
2wd
Ok...sounds like an good option ... who can do this ?
Old Jan 15, 2011 | 01:00 PM
Any half decent machinist can do this, best people to use are the old retired hobby type people.
Get a local magazine about modelling in minature or similar, this will give you loads of leads, if not at least it will give you club details, then contact the club and ask who could do a small machining job for you, it will only take about about 1/2 hour to do start to finish, it wil be reamed to suit after the plug of oilite is pressed in, you won't be able to even feel any movement, but it will rotate perfectly.
Maybe have a look in GULEX ?.
Old Jan 15, 2011 | 02:24 PM
2wd's Avatar
2wd
ok...thanks .. I'll have a go at it
Billy_RS
16
Oct 11, 2025 09:41 PM
JK12
33
Apr 26, 2021 12:09 PM
skypeller
Sep 19, 2015 09:58 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
MrsFrog
25
Oct 12, 2004 06:20 PM
