red l8 vs green l8
Old Jan 12, 2011 | 11:27 AM
saph-mad's Avatar
saph-mad
Default red l8 vs green l8
hi im on the look out for an l8 ecu but i know theres differences in them but could anyone tell me what it is ???
Old Jan 12, 2011 | 11:54 AM
Stu @ M Developments's Avatar
PassionFords Creator
Nothing at all mate, they are physically the same, only the chip that was fitted in the factory was different, and I suspect you wont be using that anyway?
Old Jan 12, 2011 | 12:14 PM
oldford's Avatar
oldford
Like Stu said, no hardware differences at all.
What differences do you think there are?
Old Jan 12, 2011 | 04:53 PM
saph-mad's Avatar
saph-mad
I've a 2wd sapphire and was told that if I fit an l8 I've to mod two wire on the tps sensor and I don't want to have to start that crap
Old Jan 12, 2011 | 04:58 PM
You will have to fit a L8 loom as well then mate. And the PF09 TPS.
Old Jan 12, 2011 | 06:13 PM
oldford's Avatar
oldford
And you need a remap.
Don't know what will happen if you do not add the knock sensor the standard L8 has.
Why the L8?
Old Jan 12, 2011 | 06:16 PM
martysmartie's Avatar
martysmartie
As said about the differences, the reason people swap the wires is that the PF01 and the PF09 outputs are reversed (I.E 5V at no throttle with a decreasing value according depending how far the throttle is opened) PF01 is also contains a switch as it is open circuit with no throttle IIRC. L8 expects to see the reverse of the above.
Stu out of interests what are the other differences between the two looms then?
Martin
Old Jan 12, 2011 | 07:45 PM
saph-mad's Avatar
saph-mad
Was told its better than the l6 as u can add coil pack / closed loop / anti lag and so on but I wouldnt be doin that for a bit
Old Jan 13, 2011 | 06:46 AM
oldford's Avatar
oldford
For all those goodies the P8 would be better.
But you have to add wiring for the Oxygen sensor if you want closed loop.
Old Jan 13, 2011 | 07:50 AM
Nothing, its a normally open sensor so the ECU wont know its not there. The engine will though when it detonates and blows up. LOL
L8 can do all that no problem and works out a similar price once a driver is installed. VERY few people can supply a good P8 calibration that will work WITHOUT the lambda sensor though, so take care when you choose...
Old Jan 15, 2011 | 05:08 PM
saph-mad's Avatar
saph-mad
so what wires is that u have to swicth round ?
ive been told that its two wire at the tps but which two ?
i know its a bit of topic but can u get copied injectors as in cheap dirt ?
Old Jan 15, 2011 | 05:58 PM
martysmartie
The done thing is to swap the wires on the TPS itself, this is for the reason I mention above, HOWEVER Stu says you should fit the loom and PF09 TPS as well, I don't know why this is perhaps he can elaborate?
I know the PF01 TPS contains a switch and is open circuit with no throttle, PF09 does not, so I think this may be why?
Martin
Old Jan 17, 2011 | 11:27 AM
mtommi's Avatar
mtommi
Is it only the green top version that only had the knock sensor? or maybe I was misinformed. It would be good to know as I do no have a knock sensor and only after installing Stu's closed loop.
Old Jan 17, 2011 | 11:35 AM
Nope, all L8 has it.
Old Jan 17, 2011 | 11:37 AM
Martin
No, you missunderstand, he said he isnt willing to swop the wires, so i replied then he will have to change the loom. Either/Or.
Correct with regards PF01/09.
Old Jan 17, 2011 | 11:57 AM
mtommi's Avatar
mtommi
Cheers Stu
Old Jan 17, 2011 | 12:08 PM
martysmartie
Ok thanks for that.
Martin
Old Jan 19, 2011 | 06:45 PM
Alvyn's Avatar
Alvyn
just for the record IF you were to swap the wires it's the 2 outter ones you do!
Old Jan 20, 2011 | 01:43 PM
James @ M Developments.'s Avatar
correct,
Old Jan 21, 2011 | 12:19 PM
Vovan's Avatar
Vovan
Hi, people. one more question:
i have a red label L8 ECU and st.2 closed loop chip for L8 (from Superchips). After chip installing i have 3.1 fault code (oxygen sensor i think). Can i connect an oxygen sensor to red label L8 ECU? Will it work correct?
Stu, is it mean that ALL L8 redtop engines has a khock sensor?
Old Jan 21, 2011 | 12:27 PM
martysmartie
The L8 hardware is the same, but the software isn't so I think it's possible to connect a Lambda also I think all vairients of 4x4 YBG and YBJ had the knock sensor. Should be on the right hand side (Exhaust) on the block at the bottom.
Martin
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
