what injector's for zetec turbo running OMEX
hi all, im hoping someone can help me with regard's to injector's...
i'v currently got cossie green injector's but i'v been told these wont work with the omex as there low impedance, but they can be used with ballast restrictor's?
firstly can anyone tell me if cossie green injector's are hi or low impedance?
sencond: where would i get ballast restrictor's?
thrid: what high impedance injector's could i use?
forth: are siemen's 55 or 85 (i think it is) high or low impedance?
any help would be awesome with this as im pretty much there with my project now, and it's just this problem with injector's that's stopping me from fireing her up for the first time
pppppllllllleeeeeaaaassssseeee help
Cossy Green injectors are Low impendance, and omex will sell you the ballast resistors for low impendance injectors along with the correct injectors if you know your required flow rate
As said Bosch dark greens 0 280 150 803 are low impedance, most ecu's are high, you can add resistors(as I have done), cost about Ł2.50 each, needing one for each injector earth line(from ecu).
If you run lows where highs are meant it could damage the ecu, though my emerald K3 worked perfect, apart from sustained high speed where the injectors were overheating and shutting down, I forgot to plug in the resistors!!
As you already have the injectors your cheapest option would be to add some resistors for Ł10 or so, most RR I should think would have these, but if you get stuck pm me and I'll pop into emerald and get 4 for you, and post them to you, can payapl me the money after, assuming you have paypal.
Cheers for the help.
Tabetha: if you coulddo that for us il love you long time
just pm us what I owe ya and il bung abit on top for your time
cheers dude!
cheers dude!
