I've messed up, need your help please
Old Mar 28, 2004 | 06:11 PM
Default I've messed up, need your help please
Removed and replaced my steering rack but made a little cock up, when pulling out the old rack i inadverntly pulled the whole steering shaft (steering wheel to rack) as well. Now i've fitted the new rack but am having problems with the following thingy, have a look at the pics please and then i'll carry on,
It fits onto the triangular shaft exiting the bulkhead, drivers footwell. What i need to know is if this thingy is supposed to fit into the hole in the bulkhead or just butt up against it.
Personnaly i feel that it does fit in as there's wear on the inner nylon thing but don't want to shove it in and cock things up further.
Please help this dumb shit out , thanks in advance
Old Mar 28, 2004 | 06:53 PM
IIRC that is one of the shaft bearings and it would need to be fixed in the bulkhead to work m8 as it supports the shaft HTH
Old Mar 29, 2004 | 05:03 PM
Does it just physically click in place?
Old Mar 29, 2004 | 08:47 PM
think it does just push in cant remember exactly though sorry
Old Mar 31, 2004 | 08:44 AM
I checked mine out last night, and it appears to press into the firewall. I tried to pull it out, and is quite hard to. Therefore I think it is a press fit. The metal cover is just that, and that comes off quite easily. I tried to take some pictures. Hope this helps. Cheers John.
Old Mar 31, 2004 | 09:02 PM
John, thankyou very much, you properly went out of your way, that is seriously appreciated. I'll be having a proper look at the weekend, those pics are very helpful.
Old Apr 1, 2004 | 07:26 AM
Hey, no problem. My engines out of the car at the moment, so the bulkhead is exposed. So I thought a few pictures might help. Although it’s LHD it will be the same as a RHD.
John
Old Apr 1, 2004 | 08:48 AM
Fozy's Avatar
Fozy
top effort JohnP. Well done mate!
Old Apr 1, 2004 | 08:54 PM
Quality help there mate Any one know if you can uprate these or is the Ford item as good as they come as mine comes loose every so often and may need replacing, any 909Ford Motorsport replacemant part?
Kyle Langford
27
Aug 5, 2019 07:54 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Churtz
Aug 20, 2015 08:12 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
