Mk3 mondeo very high revs since cruise control
Hi i have a mk3 05 petrol mondeo. The minute you start it the revs go to about 2000rpm and stay there. It gets higher still when it gets warmer. I think it has just started since a long run using cruise control. Any pointers or help would be great thanks.
if you suspect its linked to the cruise control i'd check its not opening the throttle a bit when the engine is running.
best to get someone to start the car while you watch the throtle body.
OK Gave the idle valve a cleanout with carb cleaner. Is it jst the small brown plastic bit that should move? I also gave the throttle housing a clean out. But it lasted for about a min then it soared away back up to over 2500 revs. The throttle flap was completely down meaning I presume the plate was closed and it was still revving at the 2500-3000rpm.
Took the wire off the TPS and makes no difference.
When you start it now it goes straight up to 4000rpm and stays there.
Any other pointers????
It is an 04 petrol mondeo with cruise control abs air con etc.
