Cold Start Issues
Old Dec 5, 2010 | 02:06 PM
crazy kid 1's Avatar
crazy kid 1
Default Cold Start Issues
Hi guys hope you can help...
me and a phil2002 have recently rewired my 044 fuel pump as i was only getting 7volts through original wiring loom after rewiring i have a healthy 13volts.
The problem i have got is the car will no longer tick over when cold. Has anybody got any ideas what may have caused this?
Also, is there anyway of testing the idle speed control valve?
Thanks for your help!
The car is a 3dr Sierra Cossie on level 6
Old Dec 5, 2010 | 03:44 PM
crazy kid 1
test
Old Dec 5, 2010 | 03:45 PM
forevaford's Avatar
forevaford
maybe the cars running rich now then
Old Dec 5, 2010 | 03:56 PM
crazy kid 1
maybe any other ideas
Old Dec 5, 2010 | 04:09 PM
martysmartie's Avatar
martysmartie
The easiest way to test the ISCV is to simply disconnect it with the engine running (On a cold start), if the revs drop then it shows it to be working, if no change then it's not working.
I doubt it will be running rich, if it otherwise runs ok? Easiest thing would be to check the fuel pressure.
Does it run at cold if you give it some revs?
Martin
Old Dec 5, 2010 | 04:27 PM
crazy kid 1
Martin
if i keep the revs up myself itll run but just not ticking over by herself when cold. As soon as its warm it idles fine as it did,its just this cold start issue im having thats the prob
forgot to mention i unplugged iscv made no change just cuts out mate
john
Old Dec 5, 2010 | 05:04 PM
martysmartie
Yes and so then it's the ISCV thats not working, check it's getting a 12V feed with the engine running?
Martin
Old Dec 5, 2010 | 05:40 PM
crazy kid 1
Martin
gonna check it tomorow mate,got a pal whos gona let me try his.is it normal for them to just stop working?
Old Dec 5, 2010 | 06:09 PM
Alvyn's Avatar
Alvyn
recheck the fuel pressure is correct as well as the co levels!
Old Dec 5, 2010 | 06:12 PM
martysmartie
No not really, the most common problem being they can stick which is solved by cleaning and then lubeing the valve.
Martin
Old Dec 5, 2010 | 08:39 PM
crazy kid 1
got no way of checking pressure,ill try mot garage and ask them to check co what shoukl it be? thanx for your help guys
The Enigma
13
Aug 20, 2015 09:38 PM
Bailes1992
Aug 16, 2015 07:14 PM
Archiejay
Aug 12, 2015 12:07 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
