external on acossie when?
Old Nov 28, 2010 | 10:20 AM
1cosworth's Avatar
1cosworth
Default external on acossie when?
hallo ford people . quick question how much psi i need to run in order to use an external wastegate.i ll be upgreting to greys and 1.2bars next week .cheers
Old Nov 28, 2010 | 10:35 AM
You can use a external wastegate at any pressure, but at 1.2 bar you don't need one, save your money and spend elsewhere.
Old Nov 28, 2010 | 12:52 PM
1cosworth's Avatar
1cosworth
i knew i was gonna get a negativish answer i just like the noise ofthe damn thing.thanks tabetha
Old Nov 28, 2010 | 01:11 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I run 2 bar with a internal gate
Steve
Old Nov 28, 2010 | 01:15 PM
BRAMMER's Avatar
BRAMMER
if you want one then fit one but its not needed so fitting purely for the noise
Old Nov 28, 2010 | 02:15 PM
rsmark86's Avatar
rsmark86
i run an external waste gate and screamer but its because my car runs 2.2bar on a gt35 ... but must say it sounds the nuts but as said its not cheap to make a kit up...
check out reyland as he does kits for the conversion
Old Nov 28, 2010 | 02:19 PM
Staffi's Avatar
Staffi
Cost about 2k plus and Internal will be fine..
Old Nov 28, 2010 | 02:46 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
I you want one get it done they sound the bolloxs I run an external wastegate on my fiesta cost me around £300 all in with my manifold But it's a zetec turbo not a cosworth
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
coscor86
Sep 20, 2015 01:21 PM
RSBryden
Sep 6, 2015 08:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 14, 2015 07:29 AM
