RS Cosworth Steering column
Old 09-11-2010, 08:38 PM
chrisa3
chrisa3's Avatar
Default RS Cosworth Steering column
Help
can someone tell me if the Sapphire Cosworth came with steering wheel hight adjustment??
The reason I ask, is that my 1988 2WD has, but after trying to refit he lower dash (car was bought already stripped), it doesnt fit around the steering column (height adjustment lever).
Does anyone know if I have the wrong lowerpart f the dash, or if the steering colmn has been changed in the past for a different model?? also the top of the dash seems to be a different colour to the bottom (tops like a dark grey and the bottom is solid black).
If its the latter, then i am probably going to have to cut the dash to fit as I dont really want to buy a new steering column.
can anyone with a saff leather interior post a picture of there dash board please.
thanks in advance.
Old 09-11-2010, 08:47 PM
martysmartie
martysmartie's Avatar
Hi as far as I know no MK2 (Pre facelift) had the height adjustable steering, mine hasen't if thats any help. However the facelift models (So 4x4 should as well in theory) do have it they have a lever on the left of the steering column, the steering cowling as well as the dash is totally different and so is why your having problems.
The facelift dash also had a cut out in dash to accomodate the lever and also has a opening bin on the drivers lower facia wheras yours should just have like a speaker grill cut out in it?
Martin
Old 09-11-2010, 09:36 PM
chrisa3
chrisa3's Avatar
Martin
Heres a photo of the lower dash, drivers side.
And the complete dash as it stands with the rake adjust on the steering column. The car is a 1988 2wd. So do i need a 4x4 lower dash? And the picture below shows the colour difference. Although its exagerated by the camera flash, it is two different shades.
Old 09-11-2010, 09:38 PM
scottyrs
DURHAM RSOC
scottyrs's Avatar
ive got a full spare dash mate not sure if it grey or black tho ill have a look the moro incase u need the lower part
Old 09-11-2010, 09:45 PM
chrisa3
chrisa3's Avatar
cheers
Old 09-11-2010, 09:46 PM
barry bigfin
Durham RSOC
barry bigfin's Avatar
Check out those socks!
Old 09-11-2010, 09:52 PM
chrisa3
chrisa3's Avatar
I fucking knew it, you had too didnt you. Its our lass taking the pitcures anyway, so there
Old 10-11-2010, 09:53 AM
martysmartie
Yes you have the correct dash for the car and that is why your having problems as the cars equipped with the adjustment have a different dash, I am not sure if the newer type dash would fit though as this along with the rest of the dash changed.
Martin
Old 11-11-2010, 10:48 PM
nuttynil
RS nutta
nuttynil's Avatar
im sure 4x4 sapphs had adjustable columns so at some point the column haas been changed you need a 4x4 cowling /lower das it should have a small glove box on the right .I f you need pics of mine i can post them tomorrow.Neil
Old 12-11-2010, 07:27 AM
martysmartie
Yes as I said above then, thing is do you know for certain if a facelift dash will fit an pre facelift car, I.E are the fixings in the same place etc?
On facelift dash one of the fixing screws is inside that glove box you mention.
Martin
JK12
33
26-04-2021 12:09 PM
3dr cossie
21
20-11-2015 05:00 PM
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
Quick Reply: RS Cosworth Steering column
