Help Fiesta cut out mark3 1995
Old Oct 29, 2010 | 11:04 PM
fiestafionn's Avatar
fiestafionn
Default Help Fiesta cut out mark3 1995
strory all havin serious trouble with a mk3 fiesta 95 won't start after a series of cut outs i've heard it might be the throttle senor or the coolant temp sensor i would like to know if anyone has any ideas the things been up on axle stands for ages dropped the tank and all to get at the p pump to test it and it ended up being perfect total waste of time
Old Oct 30, 2010 | 07:22 AM
Very doubtful if a cts will stop it from starting, as for the tps this is also doubtful, unless it showed no reading, test the tps 5v input and varying output with the ignition on with a multi meter.
Have you checked for a spark, checked for fuel reaching injectors, is there any rail pressure there ?
Old Oct 30, 2010 | 08:29 AM
fiestafionn
ya i have full and spark don't have a multi meter i heard that someone replaced the cps what does it stand for
Old Oct 30, 2010 | 03:40 PM
martysmartie's Avatar
martysmartie
CPS=Crankshaft Position Sensor and the fact you have spark shows this to be fine.
You could check the connector for it as it is prone for being loose although not this car in particular.
You have spark but do you have fuel reaching the rail?
Martin
Old Oct 30, 2010 | 06:24 PM
Not being funny, but if working on cars, which is usually down to high garage costs you need to buy a multi meter, just so useful for so many things, no tool box is complete without one.
Can get these from around Ł5, maplins, ebay etc, could buy 10 for the cost of a hours labour.
Old Oct 30, 2010 | 07:26 PM
fiestafionn
Martin
I'l check it all in the morning and i'l be on again tommorrow night to tell ye how i get on
Old Oct 30, 2010 | 07:27 PM
fiestafionn
no bother i'l get one asap no funds due to col
Old Oct 30, 2010 | 08:06 PM
fiestafionn
oh you might have the wrong engine in mind its got a cfi unit with one full line in and one out its got an injector in the centre bolted on above the throttle body there is no fuel rail there's a throttle sensor bolted on the side with a little arm on it that moves in sinc with the throttle lever on the t body and another sensor that looks like a solinoide that has a little rod at one end and a block connector on the other its bolted behind the lever on the t body when the t body is closed it rests on the rod pushin it back in about a centimeter when the throttle body is open the rod comes out that centimeter again i'm guessing its an idle sensor
Old Oct 30, 2010 | 08:24 PM
botters's Avatar
botters
competant bodger
this post really requires some full stops and commas
Old Oct 31, 2010 | 09:52 AM
fiestafionn
do ya wana fight about it
Old Oct 31, 2010 | 01:06 PM
fiestafionn
I havint had a chance to take the pics i will asap
Old Nov 3, 2010 | 11:34 AM
fiestafionn
I can't get the digi cam working and have change the csp sensor the car was not sparking correctly it is now the spark is also jumping a little but it shouldn't stop it from starting its like i,m not getting fuel the wires on the throotle sensor had lost some of there coating so I taped them up and they should be fine does anyone else know why the car still won't start mucho respecto to anyone with an answer
timsrs
Nov 13, 2018 11:48 AM
89barto89
Oct 4, 2015 06:59 PM
Mark_
40
Oct 2, 2015 04:40 PM
Marv888
Sep 26, 2015 03:44 PM
