poorly xr2i
Old Oct 26, 2010 | 04:01 PM
thefugs's Avatar
thefugs
Question poorly xr2i
hello there-i'm a newbie,so apologies if this question has been asked already-
ive got a 1991 xr2i,which works lovely most of the time,but occasionally (and its now happening more and more) after its had a good run somewhere and its nicely warmed up,it just refuses to start,it sounds like the starter motor wont turn over,it'll go with jump leads,but as you can imagine,its extremely embarrassing if it happens in the middle of a petrol station or something.
it starts first turn of the key in a morning,but hates itself when its warm.....any ideas? im at a complete loss
thanks
Old Oct 26, 2010 | 04:05 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
new battery time
or starter cables burnt out and shitty
alternator not giving what it shud all the time or ever
Old Nov 1, 2010 | 09:49 AM
thefugs's Avatar
thefugs
thanks,i'll give them a look into
Old Nov 1, 2010 | 10:20 AM
liam-rst's Avatar
liam-rst
shit happens
sounds like the starter is gettin too hot or wots battery is past its best, get your local garage to carry out a drop test on the battery first, most will do it for free as it only takes a sec an if its all ok then id say the starter is cack, common thing on turbo'd cvh's as starter sits right next to downpipe an gets too hot but dunno bout on n/a cvh's but id imagine so
Old Nov 1, 2010 | 10:38 AM
chaffe's Avatar
chaffe
Turbocharging Technician
my money is on the starter too, failing that change the bat and check wiring.
Old Nov 1, 2010 | 03:24 PM
Razer's Avatar
Razer
Just check the cable between the batterij to the starter and alternator, this one can be rusted inside. So when hot it gives more resistance and your starter won't turn.
Also check the connectors between the cables
Old Nov 2, 2010 | 10:43 AM
thefugs's Avatar
thefugs
thank you ppl,you're all stars,i'm getting it all looked at today
Old Nov 2, 2010 | 11:11 AM
stevo123's Avatar
stevo123
Starter motor has suffred years of heat, new motor cheap an deasy to fit
Brickhouse
14
Oct 3, 2015 07:28 PM
Andypandy260
Sep 23, 2015 10:28 PM
jason_nike
Aug 31, 2015 10:15 PM
borboyous
Aug 22, 2015 11:17 AM
Anutternutter
Aug 21, 2015 06:07 PM
