oil catch can help
Old Oct 14, 2010 | 08:01 PM
bruny's Avatar
bruny
Default oil catch can help
hi chaps again.after further more looking into the engine on my cossie i have noticed it has a baileys motorsport 4 port can installed,the thing is that it has 1 large pipe going to the rocker cover
1 going to the bottom of the engine some where
1 what points to the ground
and another smaller pipe which is unpluged and is not connected to anything,should this be going to anywer on the engine.i no the 1 what is pointing down is the atmosphere pipe.
all help is much apreciated
thanks again
Old Oct 14, 2010 | 08:15 PM
The Youth.'s Avatar
The Youth.
if the small pipe is from the bottom of the seperator then it's the drain to the sump, and will on your set up, drain back under the exhaust manifold, have a look under there and you should see the pipe screwed into the block that it has fallen off
steve
Old Oct 14, 2010 | 08:19 PM
bruny's Avatar
bruny
nice 1 mate.thanks very much.il check it out
Old Oct 14, 2010 | 08:21 PM
If it drains to the block on the turbo side then it acts as a breather also, drain is best under oil level.
There should be one large pipe inside that goes nearly all the way in to nearly touch the underside of the lid of the breather, this is your atmo pipe.
Can make a vastly more effective one for around Ł10.
Old Oct 14, 2010 | 08:31 PM
bruny's Avatar
bruny
thankyou for your reply tabetha,the little pipe what is not connected it roughly only about 6-7 inches long,but it looks as vo it has had a clamp on as the hose has the marks on.i will check both sides of the car tommorow when its light.lol
Old Oct 14, 2010 | 08:41 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
if it has 4 ports then one gos to the block turbo side one gos just under the inlet manifold one gos to the rocker cover and one gos to a catch tank to catch the oil / condensation vapour so it dosent stay in your engine
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
