MK6 1.4 Fiesta Fuel issues
Old Oct 8, 2010 | 10:28 AM
mfeltham's Avatar
mfeltham
Default MK6 1.4 Fiesta Fuel issues
Hi all,
I have a 1.4 MK Fiesta (2005 plate). Whenever is gets low on fuel, the engine will hold back when accelerating as though its spluttering. This only happens when I am running low on fuel. If I fill up the problem goes away.
I've replaced the sparks plugs and fuel filter, but still it persists. Any ideas?? Fuel pump???
Thanks,
Mark
Old Oct 8, 2010 | 10:31 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Maybe the fuel tank breather prob, vacuum builds up as the fuel gets low? does it make a noise when you open the filler cap?
Old Oct 8, 2010 | 11:14 AM
mfeltham's Avatar
mfeltham
Yes it always has done.
Old Oct 8, 2010 | 11:59 AM
chaffe's Avatar
chaffe
Needs a new cap then mate. Or drill a small hole in the excisting one (not advised)
Old Oct 8, 2010 | 12:10 PM
mfeltham's Avatar
mfeltham
Why the cap? You think the seal is knackered?
Old Oct 8, 2010 | 12:16 PM
mfeltham's Avatar
mfeltham
Also next time it happens, would unscrewing the cap slightly help?
Old Oct 8, 2010 | 12:56 PM
chaffe's Avatar
chaffe
i think it is air locked, yeah, next time it happens undo the cap and see if it cures it. If it does then the tank breather is blocked. You cannot empty the tank without air going in.
Old Oct 8, 2010 | 01:01 PM
mfeltham's Avatar
mfeltham
Ok will give it a try next time it happens. Cheers.
Old Oct 14, 2010 | 06:13 AM
mfeltham's Avatar
mfeltham
So it happened again this morning on the way to work when fuel was low. I got out and unscrewed the cap. Was fine for about 2 miles and it started again! Any other ideas?
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
