Fiesta RS1800 Cutting Out
My RS1800 used to do exactly this when I had a superchip plugged in. I gave up on it in the end and pulled it out. Might be worth checking you've not got a chip, possibly with a dodgy connection.
The other thing could be a clogged idle speed control valve.
That is why i said if applicable this as the modern Fiestas do and it's quite common to see the connectors getting knocked off with a loose boot going astray.
Good point about the Superchips modules they are a nightmare, it will be a blue module plugged into your ECU.
Martin
Martin
Mark_
40
02-10-2015 04:40 PM
