only sparks on 2 pots
Old Aug 13, 2010 | 05:30 PM
iluvaford's Avatar
iluvaford
Default only sparks on 2 pots
Hi Guys & Girls,
I have a problem with my mondeo, yesterday it suddenly started to fire on only 2 pots (1&4).
I thought it was the coil pack so removed and fitted it to a friends mondy, the result, fires all 4 pots.
After much research, i need to know if it is right that the ECU has failed.
If it has, do i need the exact same (NECK) ECU? I did try another (BASH) but it didnt even turn over let alone fire.
Thank you in advance for any help and/or advice.
Old Aug 13, 2010 | 05:49 PM
martysmartie's Avatar
martysmartie
First off before jumping at ECUs have you checked it's not the Leads or indeed the plugs themselves, even though it's unlikely to be both? If not then would look at ECU.
Martin
Old Aug 13, 2010 | 07:31 PM
iluvaford's Avatar
iluvaford
Martin
Thanks for the reply Martin,
Yes 8 plugs and 2 sets of leads and 2 coil packs cant be wrong. this is why i tried them on my mates mondy, with no problems.
This is why i'm thinking ECU.
Old Aug 13, 2010 | 08:36 PM
martysmartie
Then your probably right, I have known this to happen before and the fix seems to be to replace the actual ECU. Car woulden't have turned over as the PATS hasen't been programmed to the key.
Martin
Old Aug 13, 2010 | 10:39 PM
iluvaford's Avatar
iluvaford
Martin
I changed the ECU & The module around the ingnition barrel.
What and where is the PATS?
Old Aug 14, 2010 | 06:26 PM
martysmartie
PATS (Passive Anti Theft System) is Ford speak for the immobiliser system used the key is paired to the ECU, as such it would have to be reprogrammed with your key for it to work.
Martin
Old Aug 16, 2010 | 12:15 PM
iluvaford's Avatar
iluvaford
Hopefuly i have it sorted,
I found the PATS to go with the ECU, under the dash in drivers footwell.
gonna put it on later.
I now have the Key, ECU, PATS & ingition colar.
I'll let you know how it goes.
Old Aug 16, 2010 | 05:20 PM
iluvaford's Avatar
iluvaford
SUCSSES!
Job done, now running ace again.
Thanks to martysmartie for the advice.
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
Minirotty
11
Sep 15, 2015 10:16 PM
