What Boost??
Old Jul 20, 2010 | 07:18 PM
johnnycos's Avatar
johnnycos
Default What Boost??
What boost should a stage 3 t34 with .55 housing? run
Thanks John
Old Jul 21, 2010 | 05:50 AM
oldford's Avatar
oldford
Whatever is specified by the chip tuner.
Old Jul 21, 2010 | 06:03 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
what injectors are in the car..??
Old Jul 21, 2010 | 12:29 PM
martysmartie's Avatar
martysmartie
Stage 3 holds around 24 on average on .48, so .55 would be more, need to check AFR, det etc to make sure it's safe to run X amount of boost pressure rather than what it can make.
Martin
Old Jul 21, 2010 | 12:33 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If you have a 3 bar map sensor keep it down to 2 bar in the midrange ideally.
I run my T34 . 48 at 2.2 bar in the midrange but I have to have the 2 bar fuel set for 2.2 bar to achieve it on my map sensor, little bit pikey really, but cobblers shoes and all that
ASSUMING ITS MAPPED CORRECTLY!
Old Jul 21, 2010 | 02:04 PM
pete mcrash
Ur all giving advise when u dont know his spec...he could be on greens
Old Jul 21, 2010 | 02:08 PM
Thanks John
Depends on other mods, and what the chip is set to, ask the author of the chip you're using as he is the best person to tell you.
As an average they run around 24psi, but can't just set it to this, or at the very least if you do get a AFR check done under load.
Old Jul 21, 2010 | 02:23 PM
Chip's Avatar
Chip
I run 2.2 bar midrange on greens, no problems.
But as I mentioned in my post, it needs to be mapped correctly, and if the injectors are maxed out before you have the right amount of fuel going in then by definition it is NOT mapped correctly.
Old Jul 21, 2010 | 04:23 PM
pete mcrash
....so whats that...about 32-34psi...??.....on greens....for how long in the rev range cos usually they are fucked top end at 22psi........
Old Jul 21, 2010 | 11:06 PM
Chip's Avatar
Chip
It is down to 1.5 bar by about 6K or so, the 2.2 only lasts for a short period, probably under 1Krpm in fact.
It never climbs out of the low 11s on boost so the injectors are definately big enough.
Old Jul 22, 2010 | 05:56 AM
johnnycos's Avatar
johnnycos
Haha did'nt think it would get so much attension, well im running greys with stage2 ggr head std cams and alot more i have been chatting to someone who had simalar spec and was peaking a 33psi and held at 30 on same turbo???
Old Jul 22, 2010 | 08:51 AM
Chip's Avatar
Chip
Even on the .55 housing it wont hold 30 psi high up the rev range, especially on a modified head, the turbo just cant flow enough for that.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
