muppet needs help please.......
Old Jul 20, 2010 | 08:57 PM
  #41
jon@work's Avatar
jon@work
Originally Posted by whitty1234
Wow you realy are fantastic.
I know, thanks.
So if I understand correctly, what you've got is :
(ignore the wiring colours)
If so, then what you want is :
Old Jul 21, 2010 | 05:15 PM
  #42
jon@work's Avatar
jon@work
hang fire on the wiper motor re-wiring. Potentially interesting new development today on this thread :
https://passionford.com/forum/genera...ml#post5009439
Old Jul 22, 2010 | 09:43 AM
  #43
whitty1234's Avatar
whitty1234
Jon i cant thank you enough for all your time and patience
if you ever fancy a nice weekend up in saddleworth at my house you and the family would be more than welcome,
Old Jul 23, 2010 | 09:22 AM
  #44
whitty1234's Avatar
whitty1234
Hi jon.
need your magic touch again it has a ford capri mk1 heater and there is 3 wires in the top 1 is power others must be speed1 and speed2. Have you any idea were i connect them on a switch (how does it earth) im so close now fan fuc-ing tastic lee.
Old Jul 23, 2010 | 01:33 PM
  #45
jon@work's Avatar
jon@work
There will be a +12V supply to the switch. Two wires will then go to the heater box resistor for speeds 1 or 2, and there will be an earth from the heater box, probably either brown or black. Watch the wire sizes for this - the heater motor will probably draw around 20 amps at its fastest speed. Similarly, if you're using an aftermarket switch, make sure the one you've got is suitably rated - 25A will be fine.
Old Jul 23, 2010 | 07:01 PM
  #46
jon@work's Avatar
jon@work
Right I've had a play in the garage with a mark 1 sierra rear wiper relay. This is a big orange one with "68 125 Relais Zus. Interm. W/W Heck" on the top. If you wire it up with a sierra stalk and escort rear wiper motor, then the motor will work from the front wiper controls both intermittently (approx every 11 seconds, not adjustable) and continuously (single speed only) :
Old Jul 24, 2010 | 03:54 AM
  #47
whitty1234's Avatar
whitty1234
Jon your a god send.....................
just now need to wire the heater to rotory switch its got + 1234 on the back i have tryed all over the internet (nothing) just this and i have to try and work out the pop up headlight motor how it stops at correct hight and how it goes back must have a switch over relay im guessing. Have a great weekend jon and THANKS AGAIN
Old Jul 24, 2010 | 09:57 AM
  #48
jon@work's Avatar
jon@work
If it's one of these Durite switches, rated at 29A, that'll do fine ?
What the diagram shows is that with the switch in position I, terminals "+" and "2" are connected, and in position II, terminals "+" and "3" are connected, so you want your power going to terminal "+", and the outputs to the heater fan from terminals "2" and "3".
Old Jul 24, 2010 | 07:26 PM
  #49
whitty1234's Avatar
whitty1234
Jon again you never cease to amaze.
Thats the switch im using but i have a + from fuse to + on switch but were do i put the + from the heater ? i have blown 3 fuses trying this now (after all the wiring i have done ) nothing till what i thought would be straight forward thanks again Lee.
Old Jul 24, 2010 | 10:49 PM
  #50
jon@work's Avatar
jon@work
You shouldn't have a plus from the heater. You should have 2 lives from the switch to the heater, and an earth from the heater.
Old Aug 4, 2010 | 07:17 AM
  #51
whitty1234's Avatar
whitty1234
Hi jon.
just got back from hols.
cannot for the life of me work out the heater lets have another go...........
i have a + wire from fuse box... then there is 2 wires from the fan one must be + and other - there is 3 female connections on the top of the heater 2 connect together and 1 on its own the problem is i dont know how many speed it is ford capri mk1 by the look any idea what goes were cheers lee.
Old Aug 4, 2010 | 11:00 AM
  #52
jon@work's Avatar
jon@work
I haven't come across a mk1 capri heater box, but this is how I think it should be :
"+ from fuse box" to switch
2 wires from switch (fan is twin speed) to heater resistor pack (not direct to fan motor)
wire from heater resistor pack to earth
the 2 wires from the fan motor itself should connect to the resistor pack
Old Aug 4, 2010 | 01:42 PM
  #53
whitty1234's Avatar
whitty1234
Hi Jon.
sorted it the + from fuse goes to heater blower direct and the other wire goes to switch + and the 2 others from resistor 1 for low and the other is high.
Thank god its drove me insane but as ever thanks for the help lee.
Old Aug 4, 2010 | 06:48 PM
  #54
whitty1234's Avatar
whitty1234
Hi Jon.
What do you know about wiring a mk1 mondeo wiper motor?
spent all day cutting and welding brackets to make it fit (could not imagine only 1 speed with that rear wiper) so ive managed to get it all in now all i need to do is wire it up the tricky part is there are no wires from the motor just 5 connectors.I have tryed to undo it to see the wire colours or markings but could not see anything.Another great test for the master?
Charlie Chalk
Apr 26, 2005 01:38 PM
